New 60th Anniversary MM600 SLA081
Discussion of Seiko watches
spring-diver
Post by spring-diver » Wed Mar 05, 2025 3:17 pm
New MM600
New 8L45 movement +10-5 spd
One piece titanium case
Limited to 600 pieces
Retail EUR 5,200 Image
From Seiko:
Seiko Prospex Marinemaster Professional
Seiko Diver's Watch 60th Anniversary Limited Edition
Caliber 8L45
Driving system: Automatic
Frequency: 28,800 vibrations per hour (8 beats per second)
Power reserve: 72 hours
Number of jewels: 35
Diameter: 28.4mm, Thickness: 6.0mm
Specifications
Titanium case with super-hard coating (partly stainless steel.)
Titanium bracelet with super-hard coating, three-fold clasp with push-button release, secure lock, and slide adjuster
Dual-curved sapphire crystal with anti-reflective coating on the inner surface
Screw-down crown
Lumibrite on hands and indexes
Diameter: 45.4mm, Thickness: 16.0mm
Water resistance: 600m saturation diver’s
Magnetic resistance: 4,800 A/m
Recommended retail price in Europe: €5,200
Limited edition of 600
“A case construction using Seiko’s latest watchmaking technology”
More information Image
https://www.seikowatches.com/se-en/news ... 06_psx60th
https://www.seikowatches.com/global-en/ ... y_limited/
Sent from my iPhone using Tapatalki
Re: New MM600 SLA081
Post by hoppyjr » Wed Mar 05, 2025 3:30 pm
In a fan of the concept, but not the execution.
Seems that they have plenty of MM300 cases, so a legit reissue would be simple.
$5600 USD, even with 30% off would be $3920 and that’s just too much for what it is.
I’ll stick with the MM300 I just got, which is available new for almost half the cost.
Baffo
Re: New 60th Anniversary MM600 SLA081
Post by Baffo » Wed Mar 05, 2025 5:15 pm
They should have made the bezel a bit taller, it’s clearly too small and thin at 46mm x 16mm
The seiko design team has been hitting the izakayas pretty hard lately
Baffo
Post by Baffo » Wed Mar 05, 2025 5:16 pm
It’s 10x prettier for half the cost
Post by Wario406 » Wed Mar 05, 2025 6:28 pm
This watch is squarely in Grand Seiko territory both $$ and design. Weird and cool there’s some blending of the brands but that’s a lot of doughnuts for a new Seiko.
Post by raf42 » Wed Mar 05, 2025 6:44 pm
I vastly prefer Hoppy's (or the equivalent black version). It does not require giant fat wrists and 16mm thickness of this one is not viable. I don't hate the looks, but he size/price not so much.
Post by 59yukon01 » Wed Mar 05, 2025 6:55 pm
What's up with those lug adapter/training wheels/ eyesore. Not a fan.
Post by demer03 » Thu Mar 06, 2025 1:27 am
What’s the deal with the bolt on two piece end links?
Post by jswing » Thu Mar 06, 2025 5:54 am
According to Monochrome, "there are black-coated elements between each lug, which are secured by the back with screws, and that hold the whole watch and bezel together to ensure its resistance to pressure." My MM300s haven't fallen apart, so I'm not sure it's necessary, more of a gimmick. Overall I think it's a cool watch, but way too big and expensive for me.
Morethan1
Frequent bumper of posts
Post by Morethan1 » Thu Mar 06, 2025 7:37 am
CarloDWC
Post by CarloDWC » Thu Mar 06, 2025 9:25 am
Case, bezel and dial look awesome. Hands could be a bit better in my opinion. Price definitely too high.
Post by hoppyjr » Thu Mar 06, 2025 10:46 am
Looks better in real photos, but still…those goofy lug things…No.
Post by rockmastermike » Thu Mar 06, 2025 11:33 am
Bezel to dial ratio is not sitting well with me.
If they would shrink the whole package I’d like it a lot more
It’s just too much of a good thing as is
Post by demer03 » Thu Mar 06, 2025 11:48 am
Thanks for the edumacation :)
Snowsquare
Post by Snowsquare » Thu Mar 06, 2025 2:52 pm
It looks badass. Back to the monobloc for Seiko 👏 a proper Marinemaster, MM600.
Titanium, monobloc, 'Professional', a new calibre (8L45), and the date's at three o'clock - a lot to like, though at quite a price!
Seiko does have some history of weird end links/bezel attachments on high end divers (e.g. SBDB001, SBEX001).
spring-diver
Post by spring-diver » Thu Mar 06, 2025 6:42 pm
I have a feeling the “goofy lug things” actually hold the bezel to the case. Just like the SBDB001/011, Emperor & Darth Tuna’s. This would actually make it pretty easy to remove the bezel for cleaning/service.
kempoman
Post by kempoman » Fri Mar 07, 2025 5:23 am
If my understanding is correct it is not new on the lug design. Seiko Marinemaster SBEX001 has the same design.
https://www.ablogtowatch.com/seiko-mari ... 001-watch/
Watch collector since 1989
Mr_Pacman
Post by Mr_Pacman » Sun Mar 09, 2025 8:04 pm
So $5,200 USD get you the same bulky, mediocre ratcheting clasp system from the MM300, a "new" 8L45 movement which appears to be the same as the 8L35 but has 70 hours of power reserve and steel bezel insert with a glossy coating.
martyloveswatches
Post by martyloveswatches » Mon Mar 10, 2025 11:42 pm
Mr_Pacman wrote:So $5,200 USD get you the same bulky, mediocre ratcheting clasp system from the MM300, a "new" 8L45 movement which appears to be the same as the 8L35 but has 70 hours of power reserve and steel bezel insert with a glossy coating.
'Calibre 8L45, a new movement that’s never been used in the past. It doesn’t share its specs or jewel count with the calibre 8L35. This movement, with 35 jewels, measures 28.4mm in diameter and 6mm in thickness and is actually derived from the Grand Seiko Calibre 9S65 (same jewel count, same dimensions, same 72h power reserve). It operates at 4Hz and has a claimed accuracy here of -5/+10 seconds/day'.
Marty
Steelman
Post by Steelman » Thu Mar 13, 2025 5:02 am
It’s only $4600 retail in the US, not $5200
Only….😝
I can tolerate the bumper cars on the bezel/lugs because that is legit Seiko Marinemaster history… but I agree with rockmastermike the bezel is too big for the dial (ala Muhle Rasmus) and I can’t unsee it. It’s like the designers at Seiko said “I need more cowbell…I mean bezel!”
Post by Ryeguy » Thu Mar 13, 2025 6:34 am
I might be biased (wearing my SBDX001 as I type this), but that "mediocre ratcheting clasp system" is one of the elements I like about Seiko's engineering.
It provides a ton of extension (more than an inch I think) so truly suitable for wet suit use, and it is stone simple, with few moving parts. It can also be adjusted on the fly without removing the watch from your wrist.
On the opposite end of the complexity spectrum is theTudor Pelagos clasp, which I think is really interesting. Given the Tudor clasp's complexity, if I were to bet on which clasp would survive years of use in and around the ocean, my $ is on the Seiko.
sunking101
Post by sunking101 » Mon Apr 07, 2025 5:07 pm
Those black lug *things* are a dealbreaker. As is the price probably.
Post by CesarG » Mon Apr 07, 2025 6:35 pm
Lately?
Users browsing this forum: Djf1978 and 40 guests
