Sinn bracelet fit - again.
Discussion of Sinn watches.
Post by hoppyjr » Sun Oct 08, 2023 6:12 pm
I think there are others out there who find it difficult to get an ideal fit with a Sinn bracelet. Using a combination of links and clasp holes, I can’t find a happy place. It’s either too loose or too tight. I doubt Sinn will ever give us the micro-adjust clasp many of us want.
Well….. a quick google search and I landed on a WUS thread where someone removed the divers extension and solved their fit issue. It makes sense because we’ve long read about modern Sea-Dweller & Deepsea owners removing the divers extension and finding a better fit.
Since I’m heavy on watches for nato straps, I wanted to wear my U50P on bracelet. Removing the dive extension did the trick.
While my size spring bar is for the U50, the same concept should work on the U1 sized bracket, likely using a 20mm bar at the clasp.
Here’s what I posted in that clasp thread on WUS:
………I found myself between link-clasp fit settings: in one configuration I had the clasp adjustment as tight as possible and still it was too loose. With a link removed I was on the most loose clasp setting, but it was too tight.
Removing the divers extension, which I never use, solved the problem. Now I’m on the most loose clasp setting and the fit is ideal, no longer too tight. If my wrist shrinks in the winter, a simple pin move to the center hole will keep it just right.
While it’s true, the stock Sinn spring bar that attaches the divers extension to the clasp is too thin; there are many other types and sizes of spring bars available.
I had a bulk spring bar pack that was
originally intended for Rolex. In my case, the 17mm clasp spbar was a great fit. It appears to be 1.8 mm diameter, with a tip that is .08. I tested and found a 1.0mm tip will also fit through the hole in the clasp.
If anyone comes back to this thread, consider picking up a 17mm-18mm spring bar from Ofrei, 1.8mm diameter and with a .09 or 1.0 tip. That should be the sweet spot.
Even if you have slight play in the spring bar hole, these Sinn clasps are so heavy duty I doubt you’d ever experience a wear issue. It’s simply not the same as using a thin tipped bar in a fat hole, like Seiko or Rolex.…..
Here is the link to the thread:
https://www.watchuseek.com/threads/sinn ... s.5319540/
Edit: photos
Re: Sinn bracelet fit - again.
Post by mattcantwin » Sun Oct 08, 2023 6:25 pm
This is great, Ed; thanks. :thumbsup:
apnk
Supergluing Miscreant
Post by apnk » Sun Oct 08, 2023 6:44 pm
Thanks for the info.
Post by deepcdvr » Tue Oct 10, 2023 7:21 pm
I’ve been doing this for years - have two sinn’s set up that way now. Never had any issues :)
Post by hoppyjr » Tue Oct 10, 2023 10:13 pm
deepcdvr wrote:I’ve been doing this for years - have two sinn’s set up that way now. Never had any issues :)
You sir, are a smart man.
Post by deepcdvr » Wed Oct 11, 2023 2:20 pm
I’ve been told I’m a thinker, but the tinfoil hat sometimes interferes…
Post by hoppyjr » Wed Oct 11, 2023 2:31 pm
It’s not the tinfoil hat, it’s the tinfoil briefs that make people wonder.
pete26
Post by pete26 » Thu Oct 19, 2023 3:34 pm
Hide the tinfoil hat under Sinn cap and you will be a genius again, instead of an eccentric.
Post by deepcdvr » Thu Oct 19, 2023 3:54 pm
I actually have a Sinn hat that someone on here gave me years ago; I’ve never worn it but I’ll look for it…
The tinfoil only hides the metal plate ;)
Henryj
Bubblehead
Post by Henryj » Mon Oct 23, 2023 6:26 pm
Personally, I’d question the wisdom of anyone who spends time on the outside of a submerged submarine.
Post by deepcdvr » Fri Nov 17, 2023 5:29 pm
Lol Henry - just saw this. Coincidentally, rolling out tomorrow to do exactly that - wish me luck my friend!
Post by hoppyjr » Fri Nov 17, 2023 5:32 pm
That doesn’t sound like retirement, Paul…Image
Henryj
Bubblehead
Post by Henryj » Fri Nov 17, 2023 5:42 pm
Paul reminds me of a character in a favorite book, Cohen the Barbarian.
Post by Wario406 » Fri Nov 17, 2023 5:43 pm
Best of Luck, ALWAYS!!!
Post by deepcdvr » Tue Dec 12, 2023 6:39 pm
Hey dudes!
Thanks for the kind words - back for an air break, still kicking and definitely NOT retired, Hoppy
Btw, going to sell a Resco in the next couple of days :whistle:
Keep an eye out, these go fast!
Post by Wario406 » Tue Dec 12, 2023 6:59 pm
deepcdvr wrote:Hey dudes!
Awe fuck.
Post by deepcdvr » Tue Dec 12, 2023 7:11 pm
LMAO - OG color with bracelet
just sayin
MERRY Christmas!
Users browsing this forum: No registered users and 32 guests
