Seamaster clasp upgrade - even more awesome now
stonehead887
Post by stonehead887 » Thu Jun 27, 2019 2:37 pm
I decided to try the new Seamaster buckle upgrade on the previous version. After some research on the net i was quite sure it was possible but my AD officially said no but the the watch guy there is cool and said it would fit so paid up the £87 and it was in the AD within the week.
The new clasp is fitted to the old bracelet no issues and what a great upgrade! The sliding dive extension is perfect for small adjustments on warm days.
The clasp is longer and thicker than the original but it perfectly balances the weight of the watch and reduces the watch rotating. It still has the full dive extension if needed.
Rather strangely where the clasp connects to the bracelet, there is no movement any more. It looks like the clasp joint is machined slightly differently to avoid wiggle but it in no way impedes comfort.
I am very happy with this upgrade and can highly recommend it.
For reference the UK part number is 117STZ001159 for the 20mm bracelet
Now all I need is some of this vicious hot weather that is promised so I can puff up and try it out....ImageImageImageImageImage
Sent from my SM-G950F using Tapatalk
Re: Seamaster clasp upgrade - even more awesome now
Post by mattcantwin » Thu Jun 27, 2019 2:45 pm
Worth every penny, and then some. :cheers:
YOHOHO
Dirty Closet Hinderer Whore
Post by YOHOHO » Thu Jun 27, 2019 2:49 pm
very nice!
Post by JP Chestnut » Thu Jun 27, 2019 3:19 pm
Is that the bigger version with the most adjustment? It really looks big.
para13cord
Post by para13cord » Thu Jun 27, 2019 3:33 pm
Great upgrade. I’m still hoping Sinn will release something similar.
Post by CGSshorty » Thu Jun 27, 2019 3:48 pm
para13cord wrote:Great upgrade. I’m still hoping Sinn will release something similar.
There might be something in the works for the silicon strap.
Ruggs
Post by Ruggs » Thu Jun 27, 2019 3:53 pm
^^About time, if so.
I have one of these seamaster clasps that is homeless at the moment if anyone is interested.
Post by matt.wu » Thu Jun 27, 2019 4:11 pm
I may need that to put on an older Omega bracelet. Can you hold it for me while I check compatibility?
Post by mattcantwin » Thu Jun 27, 2019 4:31 pm
I got this info from Rob at Topper's a while back:
The clasp ending in 4666 is 34.5mm long.
The clasp ending in 1154 is 39.5mm long.
The clasp ending in 1159 is 44mm long.
Clasp 4666 has 3 adjustments, while 1154 and 1159 both have 6 adjustments.
Post by mattcantwin » Thu Jun 27, 2019 4:33 pm
A Sinn rep at the NYC WatchBuys Road Show told me something was in the works for the bracelet.
It would be great if that works out to be true.
Post by JP Chestnut » Thu Jun 27, 2019 4:34 pm
Thanks for the information. I need to get a couple of these, but I definitely don’t want the long one.
Post by raf42 » Thu Jun 27, 2019 5:42 pm
I believe the reason the 1159 is longer is because of the the diver's extension portion (I noticed my 2018 Seamaster clasp was longer than my SMC300 1154 clasp and then realized it had the diver's extension). Unless I'm mistaken, both the 1154 and the 1159 have the same 6 positions (Ed now has my SMC300 so that's from memory). The 4666 clasp only has 3 positions, so unless it's a perfect fit when closed on a "cold" wrist, it's not as useful. I'd guess the 1154 is the one you want.
Ruggs
Post by Ruggs » Thu Jun 27, 2019 5:59 pm
Sure. I’ll pm you the serial #’s
1954Selmer
Post by 1954Selmer » Thu Jun 27, 2019 6:20 pm
It was worth every single penny! Looks great and I bet it fits great.
para13cord
Post by para13cord » Thu Jun 27, 2019 6:46 pm
I remember you mentioning that, I was disappointed they didn’t show it at baselworld.
Definitely worth the small size increase on the Omega :thumbsup:
Post by deepcdvr » Thu Jun 27, 2019 7:10 pm
Yessir - only reason I flipped all three of my U-1’s :thumbsup:
Post by CGSshorty » Thu Jun 27, 2019 7:12 pm
Luckily, the bracelet fits me perfectly. I can’t wear the silicone strap, though.
Post by deepcdvr » Thu Jun 27, 2019 7:19 pm
Weird - the silicone strap works great for me ;)
The watch is too heavy on the bracelet, though, for a non-adjustable clasp on my wrist; changes dimensions too much throughout the day :shrug:
