Seiko SRPC61, 63, 65, 67, 68
Discussion of Seiko watches
Post by toxicavenger » Wed Aug 01, 2018 9:08 am
Re: Seiko SRPC61, 63, 65, 67, 68
Post by jeckyll » Wed Aug 01, 2018 9:19 am
It's a bit Halios Puck-like. but it looks interesting.
If you believe the doctors, nothing is wholesome; if you believe the theologians, nothing is innocent; if you believe the military, nothing is safe.
--Lord Salisbury
Post by toxicavenger » Wed Aug 01, 2018 9:27 am
Description
Features:
Drilled lugs
Stainless Steel Case
Stainless Steel Bracelet
Automatic Movement
Caliber: 4R36
24 Jewels
Hardlex Crystal
Black Dial
Analog Display
Luminous Hands And Markers
Day And Date Display
Rotating Bezel
Screw Down Crown
See Through Case Back
Deployment Clasp
100M Water Resistance
Approximate Case Diameter: 44mm
Approximate Case Thickness: 13mm
Would be a cool mod with some different hands.
Post by Panerai7 » Wed Aug 01, 2018 9:59 am
Looks really cool T.
Guess since it's only 100M they're not screwed down crowns?
Post by 59yukon01 » Wed Aug 01, 2018 10:08 am
I believe I've read these being referred to as "bottle caps" now.
Post by toxicavenger » Wed Aug 01, 2018 10:11 am
I can't find a definite on it but I think you are right. :salute:
Post by jeckyll » Wed Aug 01, 2018 10:51 am
That actually fits :)
Edit: I think the blue is my fav.
--Lord Salisbury
four20
Post by four20 » Thu Aug 02, 2018 6:05 am
Creation has em at $180 on bracelet. Not bad at all
Post by dnslater » Thu Aug 02, 2018 6:29 am
I like it. Design is essentially a Tuna with the shroud removed. I'm sure this is what inspired it.
Post by 59yukon01 » Thu Aug 02, 2018 6:55 am
Now's your chance to get one cheap. Massdrop has all versions starting at $149.99.
https://www.massdrop.com/buy/seiko-srpc ... atic-watch
Post by Ryeguy » Thu Aug 02, 2018 7:27 am
It says screw down crown in the specifications Terry posted.
I'm guessing, if the crown is screw down, then the water resistance is likely above 100m, but Seiko doesn't test beyond 100m for cost reasons.
Funky watch. I'd wear the blue one.
Post by jeckyll » Thu Aug 02, 2018 7:33 am
I thought all Seiko 5's were 100m. It could be a "5" thing.
Really if it has a screw down crown, I'd dive it. Image
Blah blah smrt phone
--Lord Salisbury
Post by Ryeguy » Thu Aug 02, 2018 7:38 am
Yes, that is correct too. I forgot about that "5" thing.
I agree as well about the dive thing. I trust the water resistance of a 100m rated Seiko more than I do a the water resistance of a 1,000m rated micro.
four20
Post by four20 » Thu Aug 02, 2018 7:44 am
The Frankenmonster was 200m, IIRC
Post by toxicavenger » Thu Aug 02, 2018 8:02 am
No cash but I would love to try one out
CarloDWC
Post by CarloDWC » Thu Aug 02, 2018 8:37 am
Very nice models, I wish they did not have the 5 logo on the dial though, nor the writing "Sports"...
Grahamcombat
Post by Grahamcombat » Thu Aug 02, 2018 8:55 am
Ryeguy wrote:Yes, that is correct too. I forgot about that "5" thing.
Why?
Post by Panerai7 » Thu Aug 02, 2018 9:22 am
Yeah I don't care about the rating as long as the crown is screw down, so that's good to know :thumbsup:
Post by Panerai7 » Thu Aug 02, 2018 9:28 am
SRPC65 is sold out. Was going to order for that price.
Post by Ryeguy » Thu Aug 02, 2018 9:41 am
Why?
Because I believe Seiko actually tests their watches to their rated depth. Plus, I've had decent luck with their Mahwah, NJ customer service center in the event something does go wrong.
Fullswing claims to have a pressure tester (although the photo on their site shows a unit designed to test only a single case at a time which would be problematic given the number of watches they produce) and Dan at OWC has sent me photos of his set up. Other than those micros, I'm not certain if any of them actually test their cases. I think most just rate their watches based upon a theoretical pressure resistance based upon the materials and design.
Post by toxicavenger » Fri Aug 17, 2018 2:30 pm
No Seiko 5's come with a screw down crown. I have confirmed this.Thanks to Chris I just picked this mod up
It is a SRPC61 dial in a SRPC65 case.
1954Selmer
Post by 1954Selmer » Fri Aug 17, 2018 2:38 pm
Looks Great!
Post by toxicavenger » Fri Aug 17, 2018 3:43 pm
The case is exactly the same size as the solar tuna. The lume is whiter than most seiko's imo. It uses spring bars with a .9mm tip, and it is like a black chrome finish on the watch. Bezel operates really good on it. If it had a screw down crown it would be even nicer.
Post by HapaHapa » Fri Aug 17, 2018 8:42 pm
toxicavenger wrote:No Seiko 5's come with a screw down crown. I have confirmed this.Thanks to Chris I just picked this mod up
Frankenmonster has screw down crown
Post by HapaHapa » Fri Aug 17, 2018 8:45 pm
toxicavenger wrote:The case is exactly the same size as the solar tuna. The lume is whiter than most seiko's imo. It uses spring bars with a .9mm tip, and it is like a black chrome finish on the watch. Bezel operates really good on it. If it had a screw down crown it would be even nicer.
Kind of reminds me of the Evant. Yous guys probably think I'm nuts.
Users browsing this forum: hidden by leaves and 3 guests
