mm300 clasp spring bar
Hi does any one know what size spring bar is used for the mm300 clasp I have no clue help needed . Also where to find one in the US
much thanks
much thanks
Re: mm300 clasp spring bar
I would assume standard 20mm Seiko fat spring bars. Can be had at multiple sellers.
both ends of the clasp (not bracelet) takes 18mm if i'm not wrong.
Sorry. I missed "clasp" and was thinking end links.seizure wrote:both ends of the clasp (not bracelet) takes 18mm if i'm not wrong.
They are the same size and diameter as the ones used for the Sumo and Monster clasps.
Thank you all still cant find one
I got one for john but just a heads up this isn't a normal 18mm, it has a weird dog dick head on it for it to fit tightly into the clasp. so a regular one won't work.
http://www.clockmaker.com.au/diy_seiko_7s26/diy73_3.jpg
thank you
Does any one know the diameter of the two holes in the mm300 clasp ?
Users browsing this forum: No registered users and 71 guests
