Does anyone know if the SAS 01 Classic bracelet
Moderator: Graeme
fits the SAS Air watch? The cases seem similar enough...
Re: Does anyone know if the SAS 01 Classic bracelet
Graeme mentioned that the end links will be loose because of the differences in the case backs.
Thank you for the data and good to know. The search continues...
Not a perfect fit but it's pretty close
It doesn't look bad. Do the end links rock in the lugs?DaveT wrote:Not a perfect fit but it's pretty close
Thanks man, too bad the watch is now with Matt...
It's only off by a little bit, maybe 1-2mm's max so not really "rocking" just a little bit of playJP Chestnut wrote: It doesn't look bad. Do the end links rock in the lugs?
It's wearable as is (with a little rattle) and i'm sure a small piece of masking tape under the back side would snug it up. I just wanted to try it out to see how it looked but the bracelet is too heavy for me and it's already back on the Drew canvas
and staying with him.carlodwc wrote:Thanks man, too bad the watch is now with Matt...
Good for you!mattcantwin wrote:and staying with him.carlodwc wrote:Thanks man, too bad the watch is now with Matt...
It actually looks pretty nice.DaveT wrote:It's only off by a little bit, maybe 1-2mm's max so not really "rocking" just a little bit of playJP Chestnut wrote: It doesn't look bad. Do the end links rock in the lugs?
It does look good with the bracelet..
Users browsing this forum: No registered users and 218 guests
