Kiln Dried Firewood?
Post by mattcantwin » Thu Sep 13, 2018 8:58 am
Pretty much heat my house (small ranch) with a wood burning stove; been doing this for over 30 years.
I have a firewood delivery set for next week.
Yesterday, I came across an ad for kiln dried firewood and called to ask about it.
The salesman claims it is much more efficient than typical firewood; gives a longer, hotter burn with very little ash.
He said a pallet (which is about 1/3 cord) heats about the same as a full cord of regular firewood.
Naturally, it is much more expensive than typical firewood.
Any one have any experience with it?
stonehead887
Re: Kiln Dried Firewood?
Post by stonehead887 » Thu Sep 13, 2018 9:48 am
I have kiln dried wood for a small enclosed wood burner. Compared to some other logs, they burn fast, we will get through 6 or 7 good sized logs in about 3 to 4 hours. It's great for splitting out kindling as that really goes up quickly
Sent from my SM-G950F using Tapatalk
Post by dnslater » Thu Sep 13, 2018 9:58 am
I don't specifically, but it would make sense that dryer wood combusts cleaner and more efficiently than wood with a higher moisture content. Would also produce less creosote in the chimney. The kiln drying process will make it very dry, but if you then store it outside, it will re-absorb humidity from the air and probably not be any better than well seasoned firewood. I guess it comes down to how you store it and how dry/seasoned your normal firewood is?
My parent's heated their home with wood for 30+ years as well with some supplemental ceiling heat. My dad had a large shed for wood and would rotate the newly chopped wood so he was always burning wood that was aged several years. If you don't have this luxury, kiln drying may have some benefit.
As far as the claim that it produces three times the energy, that sounds like pure sales bullshit. Maybe compared to wet wood, but the comparison against seasoned firewood couldn't be that different as the moisture content difference is only 10-15%.
Post by Ryeguy » Thu Sep 13, 2018 11:36 am
^^^ Agree with Nick.
Actually all those years of splitting and stacking firewood for my Dad when I was a kid has allowed me to appreciate my remote controlled gas fireplace.
Pour wine, sit, click button = fire. Beautiful.
Post by toxicavenger » Thu Sep 13, 2018 12:46 pm
Kiln firewood can get your fireplace to hot and burn your chimney out. Also it burns to fast. Not worth the extra cost at all imo.
Post by ericf4 » Thu Sep 13, 2018 12:47 pm
how do i plug my Nest thermostat into the firewood? Is there a manual online?
Post by Ryeguy » Thu Sep 13, 2018 12:55 pm
The firewood is near field communication enabled. Just take the Nest thermostat, set it to the temperature you are most comfortable at, and place it on top of the burning log.
Post by ericf4 » Thu Sep 13, 2018 1:00 pm
Sweet does the firewood support the latest bluetooth codecs? Also what frequency does it ride on?
Post by mattcantwin » Thu Sep 13, 2018 2:08 pm
Thanks for the responses.
I have a firewood delivery scheduled for Tuesday.
I think I'll go ahead with that and pick up some kiln dried wood during the heating season to see how it burns/heats in comparison.
sierra11b
Post by sierra11b » Fri Sep 21, 2018 5:20 pm
Drying wood is drying wood. But with kiln dried it's basically subjecting that wood to years long drought conditions for a short period making it burn hotter but subsequently faster. Think the recent Carr Fire in NorCal which killed people before they could evacuate. You're paying for the process though. Air takes longer but two woodworkers in my family have been doing years-long stabilization since before I was born. Time depends on your climate. First in first out for their next projects.
If you have the space double (or triple) your order of conventional wood and let the remainder sit. First in first out... Use half of the previous year order for next year and replenish 1/2 for the next. Rinse and repeat. Lived with my Grandparents for ten years as a kid and split a lot of wood. This is how they did it.
Post by mattcantwin » Fri Sep 21, 2018 5:42 pm
I'm going with the traditional firewood; delivery scheduled for tomorrow.
Once the heating season begins, I store a fair amount of wood directly behind the stove.
Seems to work well, even with wood one season old.
Post by mattcantwin » Sat Sep 22, 2018 8:49 am
I've got work to do.
Grahamcombat
Post by Grahamcombat » Sat Sep 22, 2018 9:05 am
10-12 cord a year for the first 2/3 of my life, and we did the whole process from felling the trees to stacking in the wood shed. I drove a skidder before I drove a car. My first chores after getting off the bus from school were to stoke the fire and fill the wood box.
With this house I have gone the way of the pellet and it is a pleasant way to go.
Post by BacoNoir » Sat Sep 22, 2018 12:11 pm
Reminds me, I felled 6 trees a month ago at our place in the mtns that died from Beetle kill. I need to take the chainsaw back up and and size/split it next in a few weeks when we go back up. Hoping that that pus our left over from last year will men we don’t have to buy more wood this year.
As others have said, no experience with kiln dried personally, but I would believe hotter but faster. I don’t buy the burning longer BS.
Post by mattcantwin » Sat Sep 22, 2018 12:28 pm
When I get too lazy (or old) to wheel barrow the wood from the driveway to the back yard I may opt for a pellet stove.
What's your experience with pellet stove maintenance?
Grahamcombat
Post by Grahamcombat » Sat Sep 22, 2018 1:34 pm
Easy day. It’s been super simple because I do routine cleaning on it, which is about 5 minutes a month. I run about a bag and a half per 24hr period - which is ~60lbs - so I’m dumping ash out every 10 days or so. Then vacuum once a month. Shoulda done it years ago.
Post by BacoNoir » Sat Sep 22, 2018 2:48 pm
Agree. I had two wood burners in my primary house 25 years ago and conveying to pellet with a thermostat and it was awesome. The other wood stove hardly ever got used after that.
Post by mattcantwin » Sat Sep 22, 2018 3:46 pm
A good day's work.
Post by mattcantwin » Sat Sep 22, 2018 3:48 pm
Sounds good, thanks.
Post by mattcantwin » Mon Sep 24, 2018 9:22 am
Last load.
Done.
Post by matt.wu » Mon Sep 24, 2018 9:59 am
Is central heating not an option? Or just not preferred?
Post by mattcantwin » Mon Sep 24, 2018 1:14 pm
We have base board heat, but have been heating with a wood stove for about 40 years.
We live in a small ranch and it works out fine - nice and toasty in the living room, kitchen, etc. and get to sleep
with nice, heavy blankets at night.
It does require attention throughout the day.
In addition, it looks like 1/3 of the wood just delivered will be going to the log splitter before coming into the house, but I enjoy that;
especially when my wife runs the splitter and I put the wood on it.
The splitter is a recent addition, used a maul previously.
All "this work" makes you really appreciate the heat.
Post by Captdave » Mon Sep 24, 2018 1:25 pm
As my Dad would tell me when I was growing up cutting and splitting 6 plus cord a year, you get more than one warning when you cut and split your own firewood. Unfortunately I grew up on 80 acres with plenty of trees. We heated with wood my entire time at home...after all the kids left my parents installed a central furnace Image Dad would still cut and split wood up until his passing at 72 but only as supplemental source of heat.
Post by 59yukon01 » Mon Sep 24, 2018 3:46 pm
Did I just click on the Pioneer days thread?
Excuse me while I turn both my furnaces up. I feel a draft.
Post by Chocodove » Mon Sep 24, 2018 3:48 pm
59yukon01 wrote:Did I just click on the Pioneer days thread?
Excuse me while I turn both my furnaces up. I feel a draft. Image
:lol:
Users browsing this forum: No registered users and 88 guests
