fresh install
New Computer/ TLS Issues
Re: New Computer/ TLS Issues
Was dealing with this bullshit battery issue on a Dell chromebook last night. Spent a few hours trying to update drivers/bios/etc. and thankfully big picture it's a throwaway. Not worth my time. Sorry about the derail, but this is a big part of why I hate using a computer at home. At work I can let IT fight with the f#cking machine while I work on something else. At home I'll just use my phone or tablet, or pick up a pencil. Maybe less functionality but I'm ok with that. Rant over.toxicavenger wrote:totally trueTorrid wrote: ↑Sun Jan 06, 2019 12:04 pmMost of Dell's installed stuff is hidden and looks like it belongs to Microsoft. I've dealt with this heavily on every Dell computer until I finally give up as the computer gets older and then it gets converted to some form of Linux. Dell even uses their own proprietary boot BIOS and it is a nightmare for chargers and batteries because it is default set to save battery life to prolong it. What this means is as batteries age and wear is that it causes weird functionality issues where even with a good charger it fails to recognize it and refuses to charge even a very low battery. Usually settings can be changed to force it to charge, but at some point every Dell does it and the BIOS is required to use the hardware no matter what operating system you use
Before doing the fresh install, thought I would give MS a call. They took care of the image issues here and I watched the sites I mentioned work fine while he took over my computer. And, of course, they aren't working now.
- jeckyll
Classic!BlueSky wrote:Before doing the fresh install, thought I would give MS a call. They took care of the image issues here and I watched the sites I mentioned work fine while he took over my computer. And, of course, they aren't working now.
Ha... and, of course, your image is a black x...
Edit: your emoji was a black x and now it works. Geesh...
David bro you need to start with a fresh install. That way you can make sure there isn't any bloatware/added software causing your issues.
It’s a very widespread issue. I even had a Dell I converted to Linux and sold and I never had the issue on that one. It had a small hard drive and Microsoft updates completely plugged it up so converting it to a new OS freed it up. I actually had a charger go bad and replaced it and fixed my charging problem. Sold the computer and the new owner started having the standard Dell BIOS issue almost immediately. I think I was able to play IT guy and get that fixed, but it seems like none are immune.HapaHapa wrote: ↑Sun Jan 06, 2019 1:50 pmWas dealing with this bullshit battery issue on a Dell chromebook last night. Spent a few hours trying to update drivers/bios/etc. and thankfully big picture it's a throwaway. Not worth my time. Sorry about the derail, but this is a big part of why I hate using a computer at home. At work I can let IT fight with the f#cking machine while I work on something else. At home I'll just use my phone or tablet, or pick up a pencil. Maybe less functionality but I'm ok with that. Rant over.toxicavenger wrote:totally trueTorrid wrote: ↑Sun Jan 06, 2019 12:04 pmMost of Dell's installed stuff is hidden and looks like it belongs to Microsoft. I've dealt with this heavily on every Dell computer until I finally give up as the computer gets older and then it gets converted to some form of Linux. Dell even uses their own proprietary boot BIOS and it is a nightmare for chargers and batteries because it is default set to save battery life to prolong it. What this means is as batteries age and wear is that it causes weird functionality issues where even with a good charger it fails to recognize it and refuses to charge even a very low battery. Usually settings can be changed to force it to charge, but at some point every Dell does it and the BIOS is required to use the hardware no matter what operating system you use
Terry, I will later this week when I've got some time. I'm sort of an analytical type and shit like this drives me crazy.
Thanks guys, I appreciate it.
Same here. But some shit just can't be figured out. So starting from scratch is the best solution.
Users browsing this forum: No registered users and 118 guests
