Straps For Deployant Question
Some straps are described as designed for deployant use.
What is in the design of the strap that prohibits use with a standard buckle if the tail end resembles a typical strap?
Re: Straps For Deployant Question
A deployant strap does not have a hole for the tounge of the buckle.
Greg
IME, straps designed for deployants generally have a thinner “tail” side.
Measurements proportions may also differ between the two sides of the strap depending on the type of deployant (single, butterfly, or reverse like IWC).
^ those two posts contain all the answers.
That being said, I have several deployant buckles that I wear.....
And I don't own a single deployant strap.
Greg
look at the omega strap and deployant on your po, then compare that to a regular tang buckle strap on your sinn u1
you got it matt
BTW- That strap looks awesome on the Omega...…………….
Users browsing this forum: No registered users and 122 guests
