Pin & Collar Source
Pin & Collar Source
I'm looking for a source for replacement Pins & Collars for the Seiko SRP773J1 Turtle SS bracelet. Replacement links from Seiko are marked MOEV1JLK and come with one pin & one collar, but that's an expensive way to get a collar. I found 0.90 pins & collars at Esslinger & Company, but their collars are tiny, only 0.5mm long compared to over 1mm for originals, plus their pins are plain top, which requires a collar at each end. Is there a source for OEM Seiko pins & collars, or OEM style?
Re: Pin & Collar Source
You can get collars like this online.
Look in the McMaster-Carr parts catalogue online. The sleeves are under "standard spring pins". Look at the "Metric 18-8 stainless steel slotted spring pins", part number 91610A080. $6.15 for 100 pieces.
I have ordered the spring pins but not pins. I found a possible option for pins though. Look up "standard dowel pins" in the McMaster catalogue. Choose "Metric 18-8 stainless steel dowel pins". I'm guessing the 1mm diameter pins will work. You will need to measure length. For example if you want 20mm length then the part number is 91585A093. $6.84 for 50 pieces.
Or contact Seiko....
Thanks for the McMaster-Carr idea, but the "standard spring pins" suggested are made to compress into a hole for a friction fit, i.e. a roll pin to secure two rotating parts or to provide a stop, while the collar on the bracelet is undersized, made to friction fit over the pin shaft, keeping the pin in place - a different fit & function. The pins in the bracelet are 0.90mm shaft size. MC doesn't have anything that small, which is why I went to Esslinger.HapaHapa wrote: ↑Fri Feb 22, 2019 12:11 pmLook in the McMaster-Carr parts catalogue online. The sleeves are under "standard spring pins". Look at the "Metric 18-8 stainless steel slotted spring pins", part number 91610A080. $6.15 for 100 pieces.
I have contacted Seiko Customer Service, and I'm hoping for a positive answer from them.
McMaster collars worked fine with the monster bracelet. Perhaps the newer bracelets are different, or maybe I've got the wrong part. Just have to find the right ones. Frankly, a paper clip can be made into a usable pin.
Just got off the phone with Seiko Customer Support. Their terminology is pin & fixing sleeve or fixing pipe, and they are unique for their different bracelets, which is surprising. For some watch/bracelet combinations you cannot get the pins & fixing sleeve/pipe alone, but must buy a replacement link which comes with one pin & one pipe/sleeve. For the new Turtle's they do sell them alone, a little over $6 for the pair plus tax and shipping. One replacement link is almost $15.
good infoRLS_KC wrote: ↑Mon Feb 25, 2019 8:15 amJust got off the phone with Seiko Customer Support. Their terminology is pin & fixing sleeve or fixing pipe, and they are unique for their different bracelets, which is surprising. For some watch/bracelet combinations you cannot get the pins & fixing sleeve/pipe alone, but must buy a replacement link which comes with one pin & one pipe/sleeve. For the new Turtle's they do sell them alone, a little over $6 for the pair plus tax and shipping. One replacement link is almost $15.
Wow, Coserve used to give you up to 3 additional links for free. Hell, I even got 3 free for two different Sumos yrs ago when they were strictly JDM
Likewise. I called sometime last year or the year before and those days of complimentary sht from Seiko are long gonefour20 wrote:Wow, Coserve used to give you up to 3 additional links for free. Hell, I even got 3 free for two different Sumos yrs ago when they were strictly JDM
links are now $35 if i recall.r.palace wrote: ↑Mon Feb 25, 2019 11:04 amLikewise. I called sometime last year or the year before and those days of complimentary sht from Seiko are long gonefour20 wrote:Wow, Coserve used to give you up to 3 additional links for free. Hell, I even got 3 free for two different Sumos yrs ago when they were strictly JDM
Users browsing this forum: No registered users and 127 guests
