Lifespan of OEM bands
- Americandave
Wondering if anyone here has worn out the panerai gator or leather? They seem pretty solid so I'm wondering what to expect in terms of lifespan
Re: Lifespan of OEM bands
A lot of variables - how often you wear them, relative humidity of your environment , whether you wear them while working out, etc. as a general rule of thumb based on my own experience, a Panerai oem leather strap is good to wear routinely for about 12-18 months before you want to replace it, assuming you wear it "daily" (not necessarily every single day, but certainly your primary watch/strap) and don't exercise with or abuse it.
Sent from Tapatalk
Sent from Tapatalk
rub dic butter into it and it will last longer. if you need some then let me know.
- james80
- Name: James
Does this work on rubber as well? I've had a Seiko Z22 dry up and crack.toxicavenger wrote:rub dic butter into it and it will last longer. if you need some then let me know.
- Americandave
Haha, dude there's plenty of local supply but I think I might stick to rocking it without lubetoxicavenger wrote:rub dic butter into it and it will last longer. if you need some then let me know.
Armor All. You try first.james80 wrote:Does this work on rubber as well? I've had a Seiko Z22 dry up and crack.toxicavenger wrote:rub dic butter into it and it will last longer. if you need some then let me know.
- Americandave
Rubber is generally designed not to be penetratedjames80 wrote:Does this work on rubber as well? I've had a Seiko Z22 dry up and crack.toxicavenger wrote:rub dic butter into it and it will last longer. if you need some then let me know.
I'm not sure about OEM, but REM went about 30 years.
Unfortunatelyhoppyjr wrote:I'm not sure about OEM, but REM went about 30 years.
I was never a fan either.Nomadz wrote:Unfortunatelyhoppyjr wrote:I'm not sure about OEM, but REM went about 30 years.
- Americandave
I've got mine on OEM gator with white stitching at the moment...takes a while to break in but ultimately makes for a comfy fit.
My AD has calf with white stitch inbound. Looking to build up the strap options a bit.
- polaco23
- Actually chooses to live in Detroit
- Name: Dominik
Not sure if off-topic, but a lot of "ze Germans" that come from Germany at my work (German company) all wear Nomos on stock Shell Cordovan, and they have had them for years, they look great still.
I think it will last a decade if you don't sweat it up, or get it too wet.
Panerai OEM straps are too short for my taste, so I opt for Kostas and Drew's canvas.
Panerai straps are available in XL
But I usually wear mine on my canvas
Due Schthread makes great leather protectant. It cost way more than dic butter, so you can impress you friends.
"Men are ruled by toys"
Napoleon Bonaparte
Napoleon Bonaparte
Users browsing this forum: No registered users and 120 guests
