Sinn Releases The DuoFlex Diving Watch Strap System
Re: Sinn Releases The DuoFlex Diving Watch Strap System
But... what about micro-adjustments?!
- Joeprez
- Name: Joe
People clamoring for a buckle with a ratchet (a la Rolex, Omega, Seiko and a bunch of micro brand's divers) and Sinn creates that contraption, which after reading a couple of articles I still don't understand how it works #facepalm
- tattoo chef
- <Will Skull for Food>
- Name: Don
Very convoluted system. Should have just done what Breitling did with their rubber strap system.
I've been praying for a well designed Sinn adjustable clasp to allow micro adjustments for the U1P and 1.1 on bracelet. Guess I'll keep on praying
No kidding. They ignore all the clasp requests and give us this. How do you say goofball in German?matt.wu wrote:But... what about micro-adjustments?!
Yeah... definitely A solution, but probably not the one they should have gone with. Sometimes innovation for the sake of being different isn't actually good.tattoo chef wrote:Very convoluted system. Should have just done what Breitling did with their rubber strap system.
Hahaha
- Joeprez
- Name: Joe
Thanks for posting this... still not a great solution in my opinion. You can buy a ratchet buckle from strapcode for $65... not sure if it will fit the Sinn rubber strap, but I bought one to try on one of my Seikos.tattoo chef wrote: ↑Fri Aug 16, 2019 7:42 amVery convoluted system. Should have just done what Breitling did with their rubber strap system.
I met a Sinn representative at the NYC WatchBuys Road Show and told him an adjustable clasp is long overdue.
He said something is in the works.
Disappointing if this is it.
Do those endlinks do something special?
Yeah those endlinks are horrible.
The clasp has micro adjustments, and is slightly smaller than the standard clasp. No need to use the end links and special straps.
Will the clasp work with the bracelet?CGSshorty wrote:The clasp has micro adjustments, and is slightly smaller than the standard clasp. No need to use the end links and special straps.
Yeap. Just going with everyone else on that one. It is definitely ugly.
I don’t believe so.hoppyjr wrote:Will the clasp work with the bracelet?CGSshorty wrote:The clasp has micro adjustments, and is slightly smaller than the standard clasp. No need to use the end links and special straps.
Bummer.CGSshorty wrote:I don’t believe so.hoppyjr wrote:Will the clasp work with the bracelet?CGSshorty wrote:The clasp has micro adjustments, and is slightly smaller than the standard clasp. No need to use the end links and special straps.
The adjustable clasp is in stock at WatchBuys. Unfortunately, you’ll probably need new rubber for it, as it is shorter than the current clasp.
Tegimented and black buckles will be available soon.
- Joeprez
- Name: Joe
We are lucky to have some inside info here!
- substitute
But this level of over engineering is a perfect German solution.matt.wu wrote: ↑Fri Aug 16, 2019 8:08 amYeah... definitely A solution, but probably not the one they should have gone with. Sometimes innovation for the sake of being different isn't actually good.tattoo chef wrote:Very convoluted system. Should have just done what Breitling did with their rubber strap system.
Hahaha
This quick adjustment solution requires removing the strap from the watch. That defeats the “quick adjustment” purpose.
- tattoo chef
- Name: Don
Yeah that’s weird. Maybe they are over explaining it or something. I’m sure soon we will see a video on how it works.HapaHapa wrote:This quick adjustment solution requires removing the strap from the watch. That defeats the “quick adjustment” purpose.
I love that the 015 tuna came out with a cheap but functional ratcheting clasp like 10 years ago.
Users browsing this forum: No registered users and 166 guests
