Question for fellow EZM 1.1 Owners
Discussion of Sinn watches.
bpax
Post by bpax » Sat Mar 17, 2018 2:23 pm
I'm a bit thick in the skull and cannot for the life of me figure out how to remove the bracelet.
I've broken the tip off a spring bar tool trying to get the damn thing off and was wondering if any of you have any suggestions, tips, etc.
Granted, I may have had a few pops while trying to take the thing off, but I'm fairly certain the bourbon is not the cause of my problem.
Many thanks in advance.
Post by hoppyjr » Sat Mar 17, 2018 2:43 pm
I do it the same as any other watch; hold in your hand face down, use a finger or two to put upward pressure on the end link while simultaneously releasing one end of the spring bar on that lug, keep the upward pressure on the end link so it doesn’t slip back in, then release the other end of spring bar and press up (toward the caseback) to remove.
Edit: finger not ringer.
bpax
Re: Question for fellow EZM 1.1 Owners
Post by bpax » Sat Mar 17, 2018 3:28 pm
Sat Mar 17, 2018 2:42 pm
I do it the same as any other watch; hold in your hand face down, use a ringer or two to put upward pressure on the end link while simultaneously releasing one end of the spring bar on that lug, keep the upward pressure on the end link so it doesn’t slip back in, then release the other end of spring bar and press up (toward the caseback) to remove.
Thanks. I figure it's user error more than anything.
Post by Nellipj » Sat Mar 17, 2018 4:58 pm
It is one of the more difficult ones to remove. The tolerance is very tight for the endlinks. The Sinn rubber was even more difficult on the 1.1 for me.
Post by aikiman44 » Sat Mar 17, 2018 5:32 pm
I had the bracelet on but have been unsuccessful in attaching the rubber.
Post by hoppyjr » Sat Mar 17, 2018 5:55 pm
aikiman44 wrote:I had the bracelet on but have been unsuccessful in attaching the rubber.
You just roll it on.
bpax
Post by bpax » Sat Mar 17, 2018 6:10 pm
:roll: :roll: :roll:
Post by aikiman44 » Sat Mar 17, 2018 7:00 pm
Some girl I grew up with demonstrated proper condom application using a banana on a tv talk show years ago.
