Nitrogen?
Nitrogen?
This may be old news to some, but l just learned that Sinn no longer uses inert Argon in its case fills, and instead uses Nitrogen. I find that to be pretty shitty on several levels. Firstly, the "Ar" on the dial should now be a "N2". Secondly, Nitrogen is not a noble gas, and can in fact react with some elements. Thirdly, it is not noticeably heavier or larger a gas, one of the advantages that is touted with Argon.
I realize no one is buying a Sinn because of the Ar fill, or will not buy one because it's now N2. It does seem a bit dishonest of a Sinn especially since they still tout the Ar in their description
Re: Nitrogen?
Old news, and a pretty useless and inconvenient "technology" no matter what gas they use.
Re: Nitrogen?
While I would never pay for pure Nitrogen in my tires, I suppose the advantage to using pure Nitrogen in a watch is that it would not have moisture suspended and would allow the metals to go longer without corrosion. Regular ambient air would have moisture in it.
Also, supposedly Nitrogen molecules are larger than Oxygen and would have a harder time escaping through the seals. Nitrogen is also still less reactive than Oxygen to metals. I suppose all-in-all it is better than regular air, but maybe not as good as Argon.
Re: Nitrogen?
Do the green caps mean tires are nitrogen filled? Saw those on coworkers Infiniti.
Re: Nitrogen?
I'd imagine the benefits of this "gas fill" stuff is all pretty minimal. It's another feature to help differentiate Sinn from the masses.
If it were really all that great I'd expect Sinn would use it in their "deep divers" by they don't.
No big deal, but they should remove the Ar symbol.
Re: Nitrogen?
Off the line, yes. Whether they've decided to keep filling up with nitrogen is anyone's guess. I know I haven't refilled with it.HapaHapa wrote:Do the green caps mean tires are nitrogen filled? Saw those on coworkers Infiniti.
Re: Nitrogen?
I think they should use methane with an escape valve.
Re: Nitrogen?
Re: Nitrogen?
While I don't care about which solution they choose, I would prefer them be upfront about whatever they're doing.
Honestly, I'd prefer the incoming EZM 1.1 to not include any element indication on the dial.
Re: Nitrogen?
OK, I stand corrected.CGSshorty wrote:The U2 and U1000 both use it.hoppyjr wrote:
Either way, I think gas is unnecessary in a watch.
- Safetystop
- Diving (muff) is not a team sport.
- Name: Dr. Eaton Beaver
Re: Nitrogen?
Yeah...not really. The reactive form of Nitrogen (Nr) will react with it's environment. However, non-reactive Nitrogen (N2) will not unless in the presence of Oxygen which will help dissociate the bonds. Not entirely but will help. The triple bonds of N2 need too much energy, (in a pure environment) to be considered reactive. So there really is nothing to get upset about. It's a fine replacement.namor wrote: ↑Wed Sep 06, 2017 12:08 pmThis may be old news to some, but l just learned that Sinn no longer uses inert Argon in its case fills, and instead uses Nitrogen. I find that to be pretty shitty on several levels. Firstly, the "Ar" on the dial should now be a "N2". Secondly, Nitrogen is not a noble gas, and can in fact react with some elements. Thirdly, it is not noticeably heavier or larger a gas, one of the advantages that is touted with Argon.
Re: Nitrogen?
Who is this clown?Safetystop wrote: ↑Wed Sep 06, 2017 4:00 pmYeah...not really. The reactive form of Nitrogen (Nr) will react with it's environment. However, non-reactive Nitrogen (N2) will not unless in the presence of Oxygen which will help dissociate the bonds. Not entirely but will help. The triple bonds of N2 need too much energy, (in a pure environment) to be considered reactive. So there really is nothing to get upset about. It's a fine replacement.namor wrote: ↑Wed Sep 06, 2017 12:08 pmThis may be old news to some, but l just learned that Sinn no longer uses inert Argon in its case fills, and instead uses Nitrogen. I find that to be pretty shitty on several levels. Firstly, the "Ar" on the dial should now be a "N2". Secondly, Nitrogen is not a noble gas, and can in fact react with some elements. Thirdly, it is not noticeably heavier or larger a gas, one of the advantages that is touted with Argon.
Re: Nitrogen?
He's a Doctor. Dr. SafetyStop.matt.wu wrote:Who is this clown?Safetystop wrote: ↑Wed Sep 06, 2017 4:00 pmYeah...not really. The reactive form of Nitrogen (Nr) will react with it's environment. However, non-reactive Nitrogen (N2) will not unless in the presence of Oxygen which will help dissociate the bonds. Not entirely but will help. The triple bonds of N2 need too much energy, (in a pure environment) to be considered reactive. So there really is nothing to get upset about. It's a fine replacement.namor wrote: ↑Wed Sep 06, 2017 12:08 pmThis may be old news to some, but l just learned that Sinn no longer uses inert Argon in its case fills, and instead uses Nitrogen. I find that to be pretty shitty on several levels. Firstly, the "Ar" on the dial should now be a "N2". Secondly, Nitrogen is not a noble gas, and can in fact react with some elements. Thirdly, it is not noticeably heavier or larger a gas, one of the advantages that is touted with Argon.
Users browsing this forum: No registered users and 149 guests
