Sinn service
Sinn service
I saw this comment on WUS from Al Archer and thought it might be worth something here:
There's no need to send this watch to Sinn or RGM. Any competent watchmaker can service this watch - I've serviced them before, even the Diapal versions. The Diapal requires some specific information to service (more what not to do than having to do something special) but other than that it's basically a stock ETA 7750 movement.
They do "modify" the movement to remove the seconds feature at 9 o'clock, but as you can see here it's hardly a difficult modification - they just clipped the post off and left it jagged - didn't even bother to smooth it out:
Have to say I found that a little disappointing to say the least.
As for the copper sulfate capsules, if they need replacing Sinn does sell them - all spare parts are sold through Watchbuys, which takes a long time but they do eventually get you the parts. Often they can be dried out if needed. In any case when I'm servicing a watch that uses the capsule, I keep it sealed up to prevent any moisture from getting to the capsule and potentially turning it more blue. Just needs a little common sense when dealing with these capsules.
Cheers, Al
Cheers, Al
Re: Sinn service
But at least they clean out the case shavings, so they're one up on Seiko.
Re: Sinn service
JP Chestnut wrote:But at least they clean out the case shavings, so they're one up on Seiko.
...and it only takes a few trips to Germany to get it fixed correctly.
Plus, the bonus of dealing with Watchbuys!
Re: Sinn service
You know, I love hearing from skilled watch smiths. They have a way of cutting through the marketing B/S and "mystique" and simply tell it the way it is.
Years ago I used to work with a guy who was a certified Porsche mechanic. He used to work on all these exotic cars and, while they were dream cars to me, they were just another machine to him. I'm sure Al feels the same way about a most watches.
Re: Sinn service
Love reading Al's posts. Wish there were more like him.
Re: Sinn service
I wish Al wasn't in moose knuckle country.
- Name: Paul
Re: Sinn service
i've just noticed my 857utc is running about 30sec a day slow. time to start looking around for service. i don't really want to send it to sinn.
Re: Sinn service
Try demagnetizing it first. My 103 was running similarly and was easily rectified with a cheap demagnetizer.shaneotool wrote:i've just noticed my 857utc is running about 30sec a day slow. time to start looking around for service. i don't really want to send it to sinn.
- Grahamcombat
- Name: Graham
Re: Sinn service
Al won't do it:
Sent from my iPad using Tapatalk Pro
Re: Sinn service
We can do the service if it needs it. If the amplitude and beat error is good then it might only need a regulation.shaneotool wrote: ↑Sun Feb 19, 2017 6:46 ami've just noticed my 857utc is running about 30sec a day slow. time to start looking around for service. i don't really want to send it to sinn.
- Name: Paul
Re: Sinn service
It's worth a try - looks like a demagnetizer is only about 10 bucks on ebay. I haven't had the best luck getting watches serviced, it would be nice to avoid it.CGSshorty wrote: ↑Sun Feb 19, 2017 7:46 amTry demagnetizing it first. My 103 was running similarly and was easily rectified with a cheap demagnetizer.shaneotool wrote:i've just noticed my 857utc is running about 30sec a day slow. time to start looking around for service. i don't really want to send it to sinn.
- Name: Paul
Re: Sinn service
I'll probably get in touch if the demagnetizer doesn't do the trick.toxicavenger wrote: ↑Sun Feb 19, 2017 10:23 amWe can do the service if it needs it. If the amplitude and beat error is good then it might only need a regulation.shaneotool wrote: ↑Sun Feb 19, 2017 6:46 ami've just noticed my 857utc is running about 30sec a day slow. time to start looking around for service. i don't really want to send it to sinn.
Re: Sinn service
I bought mine on Amazon. I think it was about $15 delivered. Most of them look to be the same product with different labels.shaneotool wrote:It's worth a try - looks like a demagnetizer is only about 10 bucks on ebay. I haven't had the best luck getting watches serviced, it would be nice to avoid it.CGSshorty wrote: ↑Sun Feb 19, 2017 7:46 amTry demagnetizing it first. My 103 was running similarly and was easily rectified with a cheap demagnetizer.shaneotool wrote:i've just noticed my 857utc is running about 30sec a day slow. time to start looking around for service. i don't really want to send it to sinn.
Re: Sinn service
Hey bro you can go to a clothing store and run your watch over the demagnetizer they use for the security tag on their clothes. It works also.shaneotool wrote: ↑Sun Feb 19, 2017 2:10 pmI'll probably get in touch if the demagnetizer doesn't do the trick.toxicavenger wrote: ↑Sun Feb 19, 2017 10:23 amWe can do the service if it needs it. If the amplitude and beat error is good then it might only need a regulation.shaneotool wrote: ↑Sun Feb 19, 2017 6:46 ami've just noticed my 857utc is running about 30sec a day slow. time to start looking around for service. i don't really want to send it to sinn.
Users browsing this forum: No registered users and 244 guests
