DIY Battery Change on Oil Filled? Updated to show the NEW 2!
Discussion of Sinn watches.
Re: DIY Battery Change on Oil Filled?
Post by marchone » Wed Oct 21, 2015 1:51 am
carlodwc wrote:No idea of what they use but I have seen a few posts of people using a product from 3M called Flourinert. Here is a post of someone putting this into a CW watch, with some description and devices he used:
http://www.christopherwardforum.com/vie ... php?t=4960
It seems too messy for me but surely cool and interesting. Check it out Seth, maybe this can help?
To my unscientific mind I wonder why Sinn couldn't isolate a battery chamber from the oil filled case holding the movement to facilitate battery changes. In theory like GS did with their 9F in the SBGX115/117.
Of course there's an enormous difference in WR between the two and that may be the design challenge.
namor
Post by namor » Wed Oct 21, 2015 6:20 am
Carlo - thanks so much for that link. It was easy to find that guy's patent, and it was as I thought - he puts a small piece of closed cell foam (sponge) in the case, and it compresses and expands as the temperature changes.
The bad news is that Fluorinert 770 costs a lot; the smallest sample I can find is 250cc, and that's at $180 plus shipping.
hobbit712
Post by hobbit712 » Wed Oct 21, 2015 6:35 am
I wonder how much expansion/compression would occur in a watch used only in normal situations. Not for diving or extreme temp changes. Does it become a non factor? :shrug:
instagram @watchidiotsavants
Post by andrema » Wed Oct 21, 2015 7:05 am
If you are going to keep it, why not just send it to Jack to have the oil removed and battery changed?
namor
Post by namor » Wed Oct 21, 2015 7:25 am
hobbit712 wrote:I wonder how much expansion/compression would occur in a watch used only in normal situations. Not for diving or extreme temp changes. Does it become a non factor? :shrug:
The engineers say it will change by 5% over the likely 100 degrees F it would be exposed to. But that is misleading in a way. If its filled at 70 degrees, then it will only expand for roughly 30 degrees on the upside, or contract somewhat more on the downside. Its the expansion that matters: remember why all those divers have HEVs on them. The pressure associated with a fluid expanding is significantly more problematic than that of a low density gas like helium. My thumbnail calculation is the watch probably takes 3-4 cc of oil, so it must realistically be able to contain 3.15-4.2 ccs without popping the crystal. Not a lot of difference, but that foam ought to make it a breeze.
carlodwc
Post by carlodwc » Wed Oct 21, 2015 5:19 pm
namor wrote:Carlo - thanks so much for that link. It was easy to find that guy's patent, and it was as I thought - he puts a small piece of closed cell foam (sponge) in the case, and it compresses and expands as the temperature changes.
You are welcome Seth. I had no idea of the price of the liquid... but I have seen someone over at the Wallet Friendly Watch forum that has done several watches with Fluorinet, maybe a different type. In this post he says he has a gallon of it and shows his latest project:
http://walletfriendlywatchforum.com/rea ... 157,567182
His ID is Solex and he is a good guy. I don't know if he would be willing to talk to you about this to give suggestions etc. maybe or even do the filling himself. But maybe you can ask him.
Sidheguitarist
Man of many calibers.
Post by Sidheguitarist » Wed Oct 21, 2015 9:44 pm
^^^That's an interesting idea. He's obviously one squared away dude when it comes to dinking around with watches, and he's already spent the dough for all the supplies.
Post by toxicavenger » Thu Oct 22, 2015 7:13 am
i would put a port on the case and use some astro-glide in it
Sidheguitarist
Post by Sidheguitarist » Thu Oct 22, 2015 9:04 am
toxicavenger wrote:i would put a port on the case and use some astro-glide in it
Perfect. Shorty has his fancy ass Sinn LE on the way; I'm putting in my vote for the Ter-Bear Sinn UXXX with astroglide-filled case as the nexxxt LE. Comes with a ToxicA pube under the crystal (appears to float on the outside) and complete kit: box, papers and black rubber strap on.
:salute:
Post by toxicavenger » Thu Oct 22, 2015 9:33 am
:salute:
that shit would rock, and the catch would be I can service it for you personally and you don't have to sent to schnitzeland to get it fixed. :jerk: :vlick:
jjlwis2
Post by jjlwis2 » Thu Oct 22, 2015 4:02 pm
This seriously better be a joke....
namor
Post by namor » Sat Oct 24, 2015 9:50 am
OK - Good news/bad news on this project.
The good news is its really fucking easy to do. As far as I can tell, the key is to disassemble before beginning:
Once you do this, and clean everything up, you're all set.
Use a small clear glass dish for this.
Replace battery, making sure the little plastic liner is placed to expose the negative lead in the back.
Fill the empty case completely with fluid, ensuring no bubbles are in it, and submerge it.
Place movement into fluid, let bubbles float to top, then place in case, still submerged.
Put a little sliver of closed cell foam in case back, after soaking it thoroughly in fluid.
Replace crown, and look to be sure second hand is ticking.
Finger tighten case back carefully while submerged, making sure it stays below fluid level.
Tighten caseback, wash off excess fluid, put on wrist.
So that was the good part. There is not a hint of air bubble in it, either:
The bad is that the original fill was silicone and it degraded the handset and dial lume beyond what I can live with (essentially no glow at all). So I'm shipping it to Germany anyway, using a German friend to reduce the shipping costs a bit.
Post by toxicavenger » Sat Oct 24, 2015 9:57 am
Congrats Seth. But why don't you just get IWW to relume the whole thing?
Post by kfalk » Sat Oct 24, 2015 10:03 am
Good work. My hands/markers don't have much lume left either. I like the creamy patina, so I'm going to go with the battery change and keep the dial and hands as is.
Post by marchone » Sat Oct 24, 2015 5:30 pm
Bravo!
Bummer about the silicone degrading the lume. Was that the factory spec?
Post by andrema » Sat Oct 24, 2015 5:59 pm
So it is the eBay watch...
Post by unixshrk » Sat Oct 24, 2015 6:00 pm
andrema wrote:So it is the eBay watch...
Looks to be
carlodwc
Post by carlodwc » Sat Oct 24, 2015 6:35 pm
namor wrote:OK - Good news/bad news on this project.
Hey Seth, awesome! :thumbsup:
I believe that the 3H on the dial indicate that the lume is Tritium, hence the lack of luminescence, probably. I bet the watch is more then 10 years old and therefore the Tritium paint has easily lost the lume, and it does not charge with a flashlight like Luminova...
Post by marchone » Sat Oct 24, 2015 7:30 pm
Aha.
Post by jeckyll » Sat Oct 24, 2015 8:25 pm
Excellent project documentation.
Too bad about the lume.
Post by BBK357 » Sat Oct 24, 2015 8:42 pm
I like the astroglide suggestion. Then if you need some just unwind the crown and shake some on your partners b-hole.
Post by CGSshorty » Sat Oct 24, 2015 9:03 pm
BBK357 wrote:I like the astroglide suggestion. Then if you need some just unwind the crown and shake some on your partners b-hole.
You should patent that. You'll make a fortune.
james80
Post by james80 » Sat Oct 24, 2015 10:09 pm
Slogans anyone?
Post by andrema » Sun Oct 25, 2015 6:52 am
"EZM2 - the ultimate Sin"
namor
Post by namor » Mon Dec 28, 2015 7:51 am
Follow-up on this project: I shipped the watch to Sinn on Oct 27th. USPS tracking showed it at JFK customs on the 28th, then nothing. I filed a lost package insurance claim online on November 30th. USPS disavowed any responsibility (of course). I considered it a total loss at that point.
Today, Sinn emailed me that the watch just arrived and they'll send me an estimate on the work! A belated holiday present!
Users browsing this forum: No registered users and 146 guests
