Crystal size Doxa Sub300 no T
I am looking for a new crystal for my Doxa 300 no T. I am not very happy taking it out te get measurements before I can find a proper replacement. Does anybody have the correct size, diameter and hight, of the original acylic crystal? Maybe even photo's of its silhouette?
__________________
____
_______,\____\,___
l_--- \___l---[]lllllll[] _
_(o)_)___(o)_)--(o)_)
____
_______,\____\,___
- demer03
Re: Crystal size Doxa Sub300 no T
Jack at IWW would be your best bet. Best in the biz for vintage Doxas.
On the No T.....polishing compound is your friend.
ABC Watchwerks can make you a custom sapphire
this is a no T so that won't work.streetracer101 wrote:ABC Watchwerks can make you a custom sapphire
__________________
____
_______,\____\,___
____
_______,\____\,___
. Polishing is OK but won't solve the small cracks in the dial. I can live with it but keep looking for a new crystal. Jack is probably not an option because I am in Spain. I have a lead on several crystals here in Europe but I much rather be sure about the size.demer03 wrote:Jack at IWW would be your best bet. Best in the biz for vintage Doxas.
__________________
____
_______,\____\,___
____
_______,\____\,___
- demer03
Ah. Try Nanuk over at WUS. He might be able to put you in touch with a few of the guys who have the domed plexi.
I'm not sure if you managed to find the crystal however this might do the job:
http://www.ebay.co.uk/itm/Jenny-Caribbe ... 5b0837d8c1
The crystal is for a Jenny 913 case which according to this link was the same case as the Sub300 no T:
http://diveintowatches.com/reviews-i-r/ ... bean-1000/
I've got a few 913 cased watches myself and the similarity to the Doxa can be seen straight away - including the domed crystal etc. (although my Doxa is a Sub300 T which is a slightly different size).
Great info sugarbuzz!
Until now I have managed to find a few with just not the right height. So I have quite a collection of just in case crystals.
The funny thing is I know the Rodriquezs. They have been measuring crystal for me just a few months ago to see if they would fit. Seems they overlooked this one. Also bought crystals from them for my Aquastars.
I will give it a try and let you know how it turned out.
__________________
____
_______,\____\,___
____
_______,\____\,___
Here's hoping! I'll see if I can get the dimensions off one of the cases I have (I need to remove and clean the bezel on one which appears to be gunked up). I need to source a screw down crown for one of them as well.
I just got the Crystal in as we speak. Unfortunately the size is not a match. The diameter is significantly bigger.sugarbuzz wrote:Here's hoping! I'll see if I can get the dimensions off one of the cases I have (I need to remove and clean the bezel on one which appears to be gunked up). I need to source a screw down crown for one of them as well.
The Jenny 913 crystal I received measures 30,67 mm.
Let me know how your measurements go.
__________________
____
_______,\____\,___
____
_______,\____\,___
Is it possible to cut a crystal to the correct size?AxodNovum wrote:I just got the Crystal in as we speak. Unfortunately the size is not a match. The diameter is significantly bigger.sugarbuzz wrote:Here's hoping! I'll see if I can get the dimensions off one of the cases I have (I need to remove and clean the bezel on one which appears to be gunked up). I need to source a screw down crown for one of them as well.
- demer03
These are domed plastic Chris.
10-4.demer03 wrote:These are domed plastic Chris.
- Name: paul
Hi there.
I have an incoming sub300T. The crystal looks mineral to me, right ? I saw pics and it seems to be a stepped one. Any tips about a replacement one would help much.
Thanks everyone !
Dive plexi if standard are quite esay to find with the correct measurement.
Thanks everyone !
Users browsing this forum: No registered users and 208 guests
