Rolex Sea Dweller - 40mm
Discussion of Rolex Watches.
seagoingsailor
Post by seagoingsailor » Wed Jan 03, 2018 9:21 am
Whats the general consensus on the collectibility of this model? Been perusing TRF and it seems this and the new 2017 year 43mm version are in high demand.
Re: Rolex Sea Dweller - 40mm
Post by hoppyjr » Wed Jan 03, 2018 9:25 am
The new 2017 43mm model is largely loved, as is common with most new Rolex sports models. Only time will tell if it remains popular.
I love everything about it except the cyclops.
The last generation 116600 in 40mm is likely to be collectible. It’s the last Sea Dweller that remains true to the original formula. My only issue with that model was the fit of the end links, but I would have kept mine save for the need to generate funds. It’s a great watch.
seagoingsailor
Post by seagoingsailor » Wed Jan 03, 2018 9:28 am
Looking for one/both and not much luck. Most of the 2017 models have an asking price of close to 2000.00 more then retail. Seems a little much to me.
Post by hoppyjr » Wed Jan 03, 2018 9:43 am
seagoingsailor wrote:Looking for one/both and not much luck. Most of the 2017 models have an asking price of close to 2000.00 more then retail. Seems a little much to me.
I’d wait for the initial hype to settle, maybe a year or so. Then it should be closer to MSRP and maybe lower.
The 40mm 116600 is only going up IMO. Post a “WTB” in that forum and maybe someone here will part with one.
Post by Chocodove » Wed Jan 03, 2018 9:43 am
I'm biased since I own one, but I consider the previous 116600 to be the greatest modern Rolex sports watch. It's production run is miniscule compared to the other modern references and as Hop said it's the only one to remain true to the five digit vibe. Prices are a bit nuts on them at the moment compared to what they were selling for as little as a year ago, though I don't really see them going down any time soon.
seagoingsailor
Post by seagoingsailor » Wed Jan 03, 2018 9:45 am
Spoke to someone at my AD yesterday. Stated that most Rolexes are going to see an MSRP jump in May. Should have picked up the 43mm version when I had the chance.
TSD
Post by TSD » Wed Jan 03, 2018 10:17 am
There are SD's for every wrist now, if you have patience. Personally, I found that the 5 digit references (16660 & 16600) just fit me best. Matte dial Triple-Six's are more on the vintage end of the spectrum, with gloss dial 16600's closer to the modern version. Like Hop said, the 116600 is the end of an era, and a great wearing watch if you appreciate the look of a modern, ceramic bezel, and want a Glidelock. My preferences run toward the pre-ceramic 5 digit case, which feels less top heavy to me.
It's tough to find them side-by-side in a case, but there are many good 5 digit vs. 6 digit comparisons outside the TRF echo chamber.
http://watchesbysjx.com/2014/07/compari ... hotos.html
I'd like to borrow a 126600 for a while, just to try one. But that watch is aiming for a totally different segment of Rolex owners, especially guys with a larger wrist, say 7.5" and up.
Try on all the different references, and then keep your eyes open. It was the most fun I had searching for the right watch.
seagoingsailor
Post by seagoingsailor » Wed Jan 03, 2018 10:37 am
Appreciate your insight on things. The 116600 would be a good fit as I have a smaller wrist. I feel as though the newer model SD might be a bit on the bulky side, but wouldnt mind one as a collectors item. My Submariner fits and feels great. Feeling that a 40mm is the way to go....at least for me.
Post by hoppyjr » Wed Jan 03, 2018 10:54 am
I also have a 5-digit 16600 and find it fantastic. My A-series is nice because it has the updated 3135 movement, super luminova lume, sapphire crystal, but also retains drilled lug holes and the SEL bracelet.
Post by JP Chestnut » Wed Jan 03, 2018 11:01 am
All 16600's have SEL. It's one of the best things about that generation.
Post by dukerules » Wed Jan 03, 2018 2:03 pm
I love the 116600, but I would not pay the current premium for one. That said, I suspect it will become a very collectible watch. I'll stick with my humble 16600--I've owned some nice watches over the years, but it's still my all-time favorite.
seagoingsailor
Post by seagoingsailor » Wed Jan 03, 2018 2:42 pm
JP and dukerules....appreciate the opinions and information.
TSD
Post by TSD » Sat Jan 06, 2018 12:05 pm
Jacobs’s comment that the DJ41 isn’t actually 41mm got me wondering if the SD43 is more like a 41.5/42. Have you tried the SD43, Hop?
That cyclops has to go, but it’d be awesome to Wu-mod one, if it wore like a 42. :shrug:
Post by JP Chestnut » Sat Jan 06, 2018 12:16 pm
I'm pretty sure it measures 43mm.
Post by hoppyjr » Sat Jan 06, 2018 12:31 pm
I’ve not seen one in the wild. Can’t Wu-mod it very easily because there is supposedly AR coating under the cyclops and it shows up noticeably if crystal is removed. This is the same as on the 42mm Explorer II’s. I’ve seen a photo of the latter and it doesn’t look good. There is also no other model crystal that would be a drop in replacement, as can be done on the 40mm models.
Post by Chocodove » Sat Jan 06, 2018 12:37 pm
I also believe it’s a true 43.
Not my pic.
streetracer101
Name: Mr Shackleford
Post by streetracer101 » Sat Jan 06, 2018 12:40 pm
LAWW can cut you a new, custom crystal.
Seppia
Post by Seppia » Sat Jan 06, 2018 12:47 pm
Chocodove wrote:I also believe it’s a true 43.
Not my pic.
I’ll go out on a limb and say it
The new SD looks like one of those micro brand “homages” to the SD, made with an oversize Chinese case and with all the elements out of proportion.
Same size dial and hands that hence look too small, super thick bezel to fill the space.
And the completely not-true-to-SD-legacy cyclops is just the icing on the turd.
When seen side by side with an older one it’s shocking how much worse it looks.
Post by hoppyjr » Sat Jan 06, 2018 12:48 pm
I didn’t even know such a thing was possible.
streetracer101
Post by streetracer101 » Sat Jan 06, 2018 12:51 pm
That's how I got rid of the old EXP2 I had. I was $100 for custom crystal or $250 for factory one at that time. I'm sure the price has since increased.
TSD
Post by TSD » Sat Jan 06, 2018 12:51 pm
I’ve seen a pic of an ExpII with the AR outline. I don’t understand. Can’t it be easily removed?
That’d be the baller route. LAWW blasted bezel insert, no cyclops. :clap:
Post by JP Chestnut » Sat Jan 06, 2018 12:53 pm
Not my pic.
Fucking enormous and the design sucks.
Post by dukerules » Sat Jan 06, 2018 12:55 pm
Not my pic.
If all of the old SDs didn't exist, it would look fine. But yeah, it's just too much.
seagoingsailor
Post by seagoingsailor » Sat Jan 06, 2018 1:03 pm
Thanks for the input and thoughts everyone. Sticking with trying to run a 116600 to ground.
poppydog
aka Nelldog
Post by poppydog » Sat Jan 06, 2018 11:40 pm
Not my pic.
Agree completely; for me, all the current diver models are ugly and have lost that classic styling.
Steve
