Advice / help from Tudor experts
- poppydog
- aka Nelldog
- Name: Steve
or anyone who does their own servicing / repairs.
I have a 1981 Tudor Sub that is finally knackered - movement works off-and-one after a vigorous shake - and I want to replace the movement with a new ETA. Can anyone tell me what tools I'll need? I've registered with Cousins UK, and thought it would make a good project for me.
Steve
Steve
Re: Advice / help from Tudor experts
You are a braver man than me. Sounds like a good challenge though
no sage advice/experience, but please document the process for us
Steve, if it was me I would get the movement serviced since that is a robust factory movement I bet the only issue with is that it is dry or the oils have thickened over time. I personally wouldn't replace it with a new one. Another problem you could run into is a new ETA mvt. might have the date window not in the exact place so your numbers might be slightly off. Then you have to worry about whether the case mount screws line up to you new mvt.
This. Why not just get the old movement serviced?dshap wrote:You want to destroy your watch's value??
+1toxicavenger wrote:Steve, if it was me I would get the movement serviced since that is a robust factory movement I bet the only issue with is that it is dry or the oils have thickened over time. I personally wouldn't replace it with a new one. Another problem you could run into is a new ETA mvt. might have the date window not in the exact place so your numbers might be slightly off. Then you have to worry about whether the case mount screws line up to you new mvt.
Do not put a new movement in it!!!
Just send it to me.
- poppydog
- aka Nelldog
- Name: Steve
Thanks fellas, I looked into getting it serviced at the AD where I purchased my SD and Sub and they told me it would have to go to Switzerland and would take best part of a year if they could do it, but that they had known older Tudors to be returned un-repaired as there were no parts. The winding stem has become detached and there are signs of rust on the rehaut.
Steve
Steve
- poppydog
- aka Nelldog
- Name: Steve
Yeah, that's the only reason I want to do it.dshap wrote:You want to destroy your watch's value??
Steve
Steve
- poppydog
- aka Nelldog
- Name: Steve
Thanks Terry, hadn't thought of that, although it's a non-date. The old movement is now obsolete according to google search (can't remember where I found that) and was hoping there'd be a modern replacement, though obviously not modified in the same way as the original. I'd rather just get it serviced but see my other post.toxicavenger wrote:Steve, if it was me I would get the movement serviced since that is a robust factory movement I bet the only issue with is that it is dry or the oils have thickened over time. I personally wouldn't replace it with a new one. Another problem you could run into is a new ETA mvt. might have the date window not in the exact place so your numbers might be slightly off. Then you have to worry about whether the case mount screws line up to you new mvt.
Steve
Steve
If it's a 2776 I will buy the mvt from you. Seriously let me know.
I'd go directly to a RSC before I gave up all hope. Sometimes AD's aren't the best resource for stuff like this. You may also want to consult a good local watchmaker in your area if you know of any.poppydog wrote:Thanks fellas, I looked into getting it serviced at the AD where I purchased my SD and Sub and they told me it would have to go to Switzerland and would take best part of a year if they could do it, but that they had known older Tudors to be returned un-repaired as there were no parts. The winding stem has become detached and there are signs of rust on the rehaut.
I bet you Jack @ IWW or ABC Watch Werks could fix that for you. So honestly I would contact them first and go from there. Hell if you need a middle man than let me know and we can figure something out. I just don't want you to get B.S.'ed on that watch. This model of movement get's work on allot so I don't think parts would be there hard to find at all.poppydog wrote:Thanks Terry, hadn't thought of that, although it's a non-date. The old movement is now obsolete according to google search (can't remember where I found that) and was hoping there'd be a modern replacement, though obviously not modified in the same way as the original. I'd rather just get it serviced but see my other post.toxicavenger wrote:Steve, if it was me I would get the movement serviced since that is a robust factory movement I bet the only issue with is that it is dry or the oils have thickened over time. I personally wouldn't replace it with a new one. Another problem you could run into is a new ETA mvt. might have the date window not in the exact place so your numbers might be slightly off. Then you have to worry about whether the case mount screws line up to you new mvt.
Send me a pm and we can figure something out.
- poppydog
- aka Nelldog
- Name: Steve
Thanks again Terry, that's really kind of you. I think I'll approach Rolex UK directly first, and then maybe see if there's a more local Rolex-trained / approved watchmaker. I don't plan on selling the watch, I just want to be able to use it again, and assumed the AD I'd spoken to was the only option. Cheers mate, DWCtoxicavenger wrote:I bet you Jack @ IWW or ABC Watch Werks could fix that for you. So honestly I would contact them first and go from there. Hell if you need a middle man than let me know and we can figure something out. I just don't want you to get B.S.'ed on that watch. This model of movement get's work on allot so I don't think parts would be there hard to find at all.poppydog wrote:Thanks Terry, hadn't thought of that, although it's a non-date. The old movement is now obsolete according to google search (can't remember where I found that) and was hoping there'd be a modern replacement, though obviously not modified in the same way as the original. I'd rather just get it serviced but see my other post.toxicavenger wrote:Steve, if it was me I would get the movement serviced since that is a robust factory movement I bet the only issue with is that it is dry or the oils have thickened over time. I personally wouldn't replace it with a new one. Another problem you could run into is a new ETA mvt. might have the date window not in the exact place so your numbers might be slightly off. Then you have to worry about whether the case mount screws line up to you new mvt.
Steve
Steve
- poppydog
- aka Nelldog
- Name: Steve
Thanks for that; good advice that hadn't occurred to me.JBZ wrote:I'd go directly to a RSC before I gave up all hope. Sometimes AD's aren't the best resource for stuff like this. You may also want to consult a good local watchmaker in your area if you know of any.poppydog wrote:Thanks fellas, I looked into getting it serviced at the AD where I purchased my SD and Sub and they told me it would have to go to Switzerland and would take best part of a year if they could do it, but that they had known older Tudors to be returned un-repaired as there were no parts. The winding stem has become detached and there are signs of rust on the rehaut.
Steve
Steve
see what they but you have to tell them that if possible you don't want any parts replaced unless it was broken. It would suck if they changed out your dial/hands and then charged you for it.poppydog wrote:Thanks again Terry, that's really kind of you. I think I'll approach Rolex UK directly first, and then maybe see if there's a more local Rolex-trained / approved watchmaker. I don't plan on selling the watch, I just want to be able to use it again, and assumed the AD I'd spoken to was the only option. Cheers mate, DWCtoxicavenger wrote:I bet you Jack @ IWW or ABC Watch Werks could fix that for you. So honestly I would contact them first and go from there. Hell if you need a middle man than let me know and we can figure something out. I just don't want you to get B.S.'ed on that watch. This model of movement get's work on allot so I don't think parts would be there hard to find at all.poppydog wrote:Thanks Terry, hadn't thought of that, although it's a non-date. The old movement is now obsolete according to google search (can't remember where I found that) and was hoping there'd be a modern replacement, though obviously not modified in the same way as the original. I'd rather just get it serviced but see my other post.toxicavenger wrote:Steve, if it was me I would get the movement serviced since that is a robust factory movement I bet the only issue with is that it is dry or the oils have thickened over time. I personally wouldn't replace it with a new one. Another problem you could run into is a new ETA mvt. might have the date window not in the exact place so your numbers might be slightly off. Then you have to worry about whether the case mount screws line up to you new mvt.
Either way I honestly don't think it is something supper serious or the watch wouldn't run at all.
If you need anything that I can help with than let me know and good luck.
What about sending it to Rikki, Ridley or the others? Ben's guy? You'll have to bite the bullet on service but I agree with Terry and don't think it's as serious as it might seem. Just needs some TLC from someone versed in vintage Rolex with a cache of parts.
Users browsing this forum: No registered users and 106 guests
