New Seamaster 300
New Seamaster 300
Thoughts? Think this one looks hot, for the most part I like pretty much all of the changes. Love the new dial construction, as well as the slight increase in dial diameter, slimmer case, etc.
https://www.hodinkee.com/articles/omega ... ntroducing
The Basics
Brand: Omega
Model: Seamaster 300
Diameter: 41mm
Thickness: 13.85mm
Case Material: Stainless steel
Dial Color: Blue or black
Indexes: Arabic and recessed markers
Lume: Yes
Water Resistance: 300m
Strap/Bracelet: Bracelet and leather strap
The Movement
Caliber: OMEGA Co-Axial Master Chronometer Calibre 8912
Functions: Hours, minutes, seconds
Power Reserve: 60 hours
Winding: Automatic
Frequency: 3.5 Hz
Jewels: 38
Chronometer Certified: Yes
The Basics
Brand: Omega
Diameter: 41mm
Thickness: 13.85mm
Lume: Yes
The Movement
Winding: Automatic
Frequency: 3.5 Hz
Jewels: 38
Re: New Seamaster 300
I love this watch so much. Only complaints are 13.85 thick it's on the cusp of "chunky" but wow I love the sandwich
Sent from my Pixel 5 using Tapatalk
Thinner case, single-line sandwich dial, lollipop, and lumed aluminum insert. Winner winner.
Looks like they are making it in bronze as well.
- demer03
That’s a beaut.
I really like the lollipop seconds hand - I remember thinking it was pretty cool back when they put it on the James Bond Spectre LE. Very nice design overall.
Agreed on all counts! Might have to be my 1st Omega. Torn between this and the White Seamaster 42.
I like it a lot.... would prefer it to be a little thinner. Omega can't seem to get the Coax movement thickness down. Didn't these wear awkward due to lug to lug length?
This design would be perfect at a BB58 size. Omega is missing out on having no divers for people that like slim 40mm or less watches.
New Seamaster 300
I love the more open cleaner dial, overall a looker but preferred the old second hand and crown. This crown is out of place on this watch for me. I also wished for a slimmer caseback.
I like that a lot actually.
I'm pretty sure I've read that the coax movements themselves aren't all that thick, so the case thickness appears to be strictly a design choice for some reason. In this instance, I'm sure the sandwich dial adds to it.dnslater wrote: ↑Tue Mar 23, 2021 7:22 amI like it a lot.... would prefer it to be a little thinner. Omega can't seem to get the Coax movement thickness down. Didn't these wear awkward due to lug to lug length?
Some of it is design choice for sure, but at least the 8500 wasn't a thin movement:JBZ wrote: ↑Tue Mar 23, 2021 7:48 amI'm pretty sure I've read that the coax movements themselves aren't all that thick, so the case thickness appears to be strictly a design choice for some reason. In this instance, I'm sure the sandwich dial adds to it.dnslater wrote: ↑Tue Mar 23, 2021 7:22 amI like it a lot.... would prefer it to be a little thinner. Omega can't seem to get the Coax movement thickness down. Didn't these wear awkward due to lug to lug length?
Omega Cal 8500/8501: 29mm diameter 5.5mm thickness (5.6mm for Cal 8501)
Omega Cal 1120: 25.6mm diameter 4mm thickness
Omega Cal 2500: 25.6 diameter 4.1mm thickness
Omega Cal 1164 (ETA 7750): 30mm diameter 7.9mm thickness
Of course, Rolex managed to stuff an even thicker movement into the fairly thin 14060M
Rolex Cal 3135: 28mm diameter 6mm thickness
and Daytona
Rolex Cal 4130: 30.5mm diameter 6.5mm thickness
I like it a lot minus going back to aluminum bezel. I understand it's a neo-vintage move but there was nothing wrong with liquid metal bezel and it was scratchproof. With a typical Omega discount this should compete well with BB58, which was probably what it was built for.
Kind of less bling for your buck, though I think Omega's matte ceramic bezels looked cool. It's a brushed case and bracelet away from being a great daily.
Agree matte ceramic from PO would have been great. I’m guessing it was easier to use aluminum in making lumed bezel? Not sure. Aluminum as charming and nostalgic as it is belongs in less expensive watches IMO. For 6K MSRP that’s just lazy, although this will be circulating for $3500 on secondary all day long
JP Chestnut wrote: ↑Tue Mar 23, 2021 7:57 am
The BB58 movement is 4.99 mm thick, so not too much thinner than the newer Omega movements. Seems like Omega should be able to slim down their cases a bit.
I wish they would do another 12 hour bezel like the seamaster spectre.
-- Eric Cartman
― Neil Gaiman, The Sandman
Floating down canal
It always just says now
But this watch is never wrong
- Jimmy Buffett
-- Eric Cartman
Floating down canal
- Jimmy Buffett
It's pretty clearly being driven by the bulging case back. Basically every Omega diver has a back that bulges as much, or more than, a Rolex SD.
The BB58 (left) doesn't have a particularly thin mid case, but the back is almost flat. If you fit the bulging Omega style back it would immediately be a chunky watch.
Love everything about it. This could bring me out of 'retirement'...
The Daytona is particularly interesting, because the watch itself is pretty thin. Of course, only 100 meters WR.JP Chestnut wrote: ↑Tue Mar 23, 2021 7:57 amSome of it is design choice for sure, but at least the 8500 wasn't a thin movement:JBZ wrote: ↑Tue Mar 23, 2021 7:48 amI'm pretty sure I've read that the coax movements themselves aren't all that thick, so the case thickness appears to be strictly a design choice for some reason. In this instance, I'm sure the sandwich dial adds to it.dnslater wrote: ↑Tue Mar 23, 2021 7:22 amI like it a lot.... would prefer it to be a little thinner. Omega can't seem to get the Coax movement thickness down. Didn't these wear awkward due to lug to lug length?
and Daytona
Have you ever tried on a SS Daytona? It wears wonderfully. I think I paid, at the time for me, the astronomical price of $10,000 for mine and I have never once regretted it. It's the perfect watch for someone who likes smaller watches.JBZ wrote: ↑Tue Mar 23, 2021 10:37 amThe Daytona is particularly interesting, because the watch itself is pretty thin. Of course, only 100 meters WR.JP Chestnut wrote: ↑Tue Mar 23, 2021 7:57 amSome of it is design choice for sure, but at least the 8500 wasn't a thin movement:JBZ wrote: ↑Tue Mar 23, 2021 7:48 amI'm pretty sure I've read that the coax movements themselves aren't all that thick, so the case thickness appears to be strictly a design choice for some reason. In this instance, I'm sure the sandwich dial adds to it.dnslater wrote: ↑Tue Mar 23, 2021 7:22 amI like it a lot.... would prefer it to be a little thinner. Omega can't seem to get the Coax movement thickness down. Didn't these wear awkward due to lug to lug length?
and Daytona
In real world use, 13.8mm thickness isn't too bad on a 41mm watch. Some of the thick boys Omega was making before were 7750 movements in 41/42mm cases. Those were like 17mm thick.
(and I still like them)
These look like a nice iteration on the SM300.
I’d be happy with 13.8. Just used the calipers on my 8500 PO and, including crystal, it’s 16mm. That hasn’t bothered me, it’s my favorite watch to wear. The balance is good enough that it’s not top heavy.
Looks great but won't be spending 6 grand. Will make do with something like an 007 mod for now.
Really is a stunner David, and the way they updated so many things
without changing the personality at all is just really terrific.
Omega seems to be doing so many cool things lately. Can't thank
you enough for the report !!!
P.S. This Bronze Gold looks to be this one's brother...
Users browsing this forum: DocHollidayDDS, gr8sw, gwells and 766 guests
