WRUW.....Friday 13th Sept 2019
Re: WRUW.....Friday 13th Sept 2019
Good morning guys. TGIF. Starting the weekend early with the newly arrived Crepas Engelsfisch.
The old standby. Seiko 6309-7040.
EDIT : pic posting problem solved! Thanks all.
- gonzomantis
- gonzomantis
- 59yukon01
- 1.21 gigawatts?!
There is some extra text between your IMG tags. Edit your post and remove the "Watch " from before "https" and it will work.
In imgur using the BBcode copy button will copy the proper format including IMG tags so you can just paste it into your post.
Tried it and still not showing up for me... Weird. I used to be able to post pics
You need to use the BBCode (or direct) url for the image, it will start with https://i.imgur.com - I assume the "i." is for imgur's "inline" in post image support, and and with an image extension - e.g. .jpg.KidKeith wrote: ↑Fri Sep 13, 2019 7:11 amTried it and still not showing up for me... Weird. I used to be able to post pics
Also an inline image needs the proper extension, in this case ".jpg", else it does not know it's an image. Your's did not have an extension, it was instead the non direct url to an imgur webpage with your picture (it included your pic, but was not a direct link to just the pic).
Like this:
Still don’t see them either on iPhone
Wearing the Mark XV today while I look for a new daily driver. 220K mile BMW finally bit the dust yesterday
Well....wore the Paradive this morning, then decided I would sell it, so quick swap to the Casio Pathfinder I just received from Carlo.
The combination of sapphire crystal and STN display make this have a nice, crisp screen.
Switched over to this Ruhla now guys...
