Uncle Seiko GL831 in 20mm
- 59yukon01
- 1.21 gigawatts?!
Re: Uncle Seiko GL831 in 20mm
Knew he had them in the works, but didn't know they were available now, so thanks for the heads up. I'll be ordering one.
Are these soft enough to squeeze into 19mm lugs?
I need both sizes. Is there a discount code?
Don’t know about the sizing question, but use WISDEAL for 10% off.TSD wrote:Are these soft enough to squeeze into 19mm lugs?
Good to hear. Hopefully he’ll release a shorter version for those of us with slimmer wrists.
Just ordered 3....
Should work on 6105. They are soft enough to give a little.
And this will be a must for the topper seiko le.
-- Eric Cartman
― Neil Gaiman, The Sandman
Floating down canal
It always just says now
But this watch is never wrong
- Jimmy Buffett
-- Eric Cartman
Floating down canal
- Jimmy Buffett
- 59yukon01
- 1.21 gigawatts?!
I've got both lengths of the 22mm and have a 7" wrist. Both work fine on the Nafts, but I do prefer the shorter version on those.
After wearing the OEM for years these are such a HUGE improvement.
- spring-diver
- Name: Shannon
Thanks T
Hopefully Larry will make a copy of the MM300 strap
Whoa that is insanely cool to find out about Terry !
Sounds like he evidently made them more comfortable too. Thank you sir !!!
i got one also. even though i do not have a seiko with 20mm lugs right now
Just came in.
On my 6105.
On my 6105.
-- Eric Cartman
Floating down canal
- Jimmy Buffett
-- Eric Cartman
Floating down canal
- Jimmy Buffett
- 59yukon01
- 1.21 gigawatts?!
I ordered the 20mm Saturday and got it today. From CA to KY??? That's fast!
I wish someone would make rubbers with a longer buckle end, say 85-90
Brands could keep a 115-120 tail end, but offer both a 70-75 buckle end and an 85-90 buckle end.
This would accommodate virtually all wrist sizes, especially if using an Isofrane style slot with close placement and many holes.
