Let’s try and remain a little realistic. I’m not a miracle worker.59yukon01 wrote:I'm only interested in this watch if it can stand the dynamic water pressure while I'm taking a shower.
Physical Oceanography/Applied Physics
- Grahamcombat
- Name: Graham
- 59yukon01
- 1.21 gigawatts?!
Re: Physical Oceanography/Applied Physics
Grahamcombat wrote:Let’s try and remain a little realistic. I’m not a miracle worker.59yukon01 wrote:I'm only interested in this watch if it can stand the dynamic water pressure while I'm taking a shower.
Will it have a 6 month return privilege?
- Grahamcombat
- Name: Graham
I’m instituting the Ares ERIC Policy: Every Ridiculously Insane Conspiracy Policy. Watches can be returned indefinitely if each story is more outlandish than the last.ericf4 wrote:Will it have a 6 month return privilege?
- JDC222
- Demander of Intro Threads
HahahahahahaGrahamcombat wrote:I’m instituting the Ares ERIC Policy: Every Ridiculously Insane Conspiracy Policy. Watches can be returned indefinitely if each story is more outlandish than the last.ericf4 wrote:Will it have a 6 month return privilege?
You should include a NATO woven from actual Matt Graham beard clippings.
- Grahamcombat
- Name: Graham
I thought dials made from my bone grafts was enough. You guys are hard to please.
- JDC222
What, no C-4 testing????
Can I pay by PayPal. It's a friend's account.
- Grahamcombat
- Name: Graham
All transactions will be handle thru email by my Uncle, who is a Nigerian Prince.
- demer03
Will astroglide penetrate the seals?
Asking for a friend....
- Grahamcombat
- Name: Graham
Where has it failed for you up until this point? Asking purely for science.demer03 wrote:Will astroglide penetrate the seals?
- demer03
Grahamcombat wrote: ↑Tue Sep 18, 2018 3:17 pmWhere has it failed for you up until this point? Asking purely for science.demer03 wrote:Will astroglide penetrate the seals?
Checking back in on this thread.
We went from applied physics to astroglide. For the record, I think we’ve generally remained on topic, when you think about it.
- Henryj
- Bubblehead
- Name: Old guy
I love Google, it’s a crutch for tired memory. I knew there was a simple calc for dynamic pressure of water based on velocity. Very short form example is 69.5 psi is the dynamic pressure of water at 70 mph. So, if you jump out of a car on the freeway into a lake, you’ll see a pressure spike of 69.5 psi assuming you don’t hit pavement first and slow down. I learned this in nuke school with pump laws. Note the relationship is NOT linear, it’s a square function for velocity vs pressure. 35 mph (1/2) drops the pressure by 4 times or 17 psi and change. Going the other way, 140 mph (double the original speed) you go up in pressure by 2 squared or four for a dynamic pressure of about 280 psi.
How fast do you want to go? And will you care what time it is when you hit?
The day is young. Give it time.
instagram @watchidiotsavants
And to bring it all home, how can Astroglide help my wrist achieve 35 mph (17 psi) while I'm showering and will the watch (and me) still function after?Henryj wrote: ↑Wed Sep 19, 2018 5:28 amI love Google, it’s a crutch for tired memory. I knew there was a simple calc for dynamic pressure of water based on velocity. Very short form example is 69.5 psi is the dynamic pressure of water at 70 mph. So, if you jump out of a car on the freeway into a lake, you’ll see a pressure spike of 69.5 psi assuming you don’t hit pavement first and slow down. I learned this in nuke school with pump laws. Note the relationship is NOT linear, it’s a square function for velocity vs pressure. 35 mph (1/2) drops the pressure by 4 times or 17 psi and change. Going the other way, 140 mph (double the original speed) you go up in pressure by 2 squared or four for a dynamic pressure of about 280 psi.
Edit: According to this G force calculator if the watch were to go in one direction at 35 mph, and then suddenly reverse direction at 35mph over the course of 1 second, my watch would achieve 3.2 G's in the shower.
https://rechneronline.de/g-acceleration/
- Henryj
- Bubblehead
- Name: Old guy
3.2 g from 35 mph to 0? That’s a bit over 16 meters. Damn big shower and a shitload of optimism.dnslater wrote: ↑Wed Sep 19, 2018 6:00 amAnd to bring it all home, how can Astroglide help my wrist achieve 35 mph (17 psi) while I'm showering and will the watch (and me) still function after?Henryj wrote: ↑Wed Sep 19, 2018 5:28 amI love Google, it’s a crutch for tired memory. I knew there was a simple calc for dynamic pressure of water based on velocity. Very short form example is 69.5 psi is the dynamic pressure of water at 70 mph. So, if you jump out of a car on the freeway into a lake, you’ll see a pressure spike of 69.5 psi assuming you don’t hit pavement first and slow down. I learned this in nuke school with pump laws. Note the relationship is NOT linear, it’s a square function for velocity vs pressure. 35 mph (1/2) drops the pressure by 4 times or 17 psi and change. Going the other way, 140 mph (double the original speed) you go up in pressure by 2 squared or four for a dynamic pressure of about 280 psi.
Of course we are speaking in pure hypotheticals.Henryj wrote: ↑Wed Sep 19, 2018 6:14 amGiven the distance you’d theoretically cover, all I can say is Aren’t we the optimist?dnslater wrote: ↑Wed Sep 19, 2018 6:00 amAnd to bring it all home, how can Astroglide help my wrist achieve 35 mph (17 psi) while I'm showering and will the watch (and me) still function after?Henryj wrote: ↑Wed Sep 19, 2018 5:28 amI love Google, it’s a crutch for tired memory. I knew there was a simple calc for dynamic pressure of water based on velocity. Very short form example is 69.5 psi is the dynamic pressure of water at 70 mph. So, if you jump out of a car on the freeway into a lake, you’ll see a pressure spike of 69.5 psi assuming you don’t hit pavement first and slow down. I learned this in nuke school with pump laws. Note the relationship is NOT linear, it’s a square function for velocity vs pressure. 35 mph (1/2) drops the pressure by 4 times or 17 psi and change. Going the other way, 140 mph (double the original speed) you go up in pressure by 2 squared or four for a dynamic pressure of about 280 psi.
- Henryj
- Bubblehead
- Name: Old guy
Anywaaaaaayy,
Static pressure at 300 meters is about 441 psi. Add the 25% for wet testing as a dive watch and we see 551 psi as a static test pressure. Even if you’re a hood ornament on a 688, you could safely go to test depth at a flank bell and the watch would be fine, but I doubt even Paul would volunteer to be the test dummy for that little caper.
- Grahamcombat
- Name: Graham
My initial thoughts were relating to surf zone and shore break and the force endured in that tumble smash.Henryj wrote:Anywaaaaaayy,
- Henryj
- Bubblehead
- Name: Old guy
You might need to worry about banging against rocks, heads, sand, random hard bits, but you won’t see any of the giant mythological pressure spikes from water that WUS desk divers get all a-flutter about.Grahamcombat wrote: ↑Wed Sep 19, 2018 7:00 amMy initial thoughts were relating to surf zone and shore break and the force endured in that tumble smash.Henryj wrote:Anywaaaaaayy,
Users browsing this forum: Axelay2003, BramleyGreg, demer03, DocHollidayDDS, gwells and 1387 guests
