Professional Scratch Removal
Post by Panerai7 » Sun Feb 11, 2018 2:17 pm
Start watching at 3:00
I literally cringed and had chest pains :lol:
Who does this on a fn hard surface????
https://youtu.be/ta_ueabmP3w
Re: Professional Scratch Removal
Post by ericf4 » Sun Feb 11, 2018 2:27 pm
Scotch tape baby. And btw the grey and red scotchbrites are the way to go. Not green. Grey is very fine, red slightly less fine. Did it today.
Rob.B
Post by Rob.B » Sun Feb 11, 2018 2:28 pm
Gonna need something to take all the scratches out of his bezel and crystal also the way he’s rubbing it up and down that smooth surface...
Rob.B
Post by Rob.B » Sun Feb 11, 2018 2:30 pm
He may as well go the whole hog and get a grinder on it...
Heuerville
Post by Heuerville » Sun Feb 11, 2018 4:01 pm
:shock:
I'm waiting for his 2nd video.. "How to easily clean your car by driving it into the ocean"
"SOB get me a drink"
Alan1972
Post by Alan1972 » Sun Feb 11, 2018 4:03 pm
Heuerville wrote::shock:
R@cerx
Post by R@cerx » Sun Feb 11, 2018 5:03 pm
Idiot
Post by fastward » Sun Feb 11, 2018 5:16 pm
Nailed it!
Post by Panerai7 » Sun Feb 11, 2018 6:18 pm
Several videos have mentioned green matches Rolex brush. How did the grey work out? Matches the rest of the bracelet?
Post by ericf4 » Sun Feb 11, 2018 6:52 pm
Grey was very fine and looks perfect on my iwc bracelet. Green seems far too aggressive whenever I've tried it.
Post by Panerai7 » Sun Feb 11, 2018 7:01 pm
Thanks for the tip. Amazon I'm assuming?
Post by ericf4 » Sun Feb 11, 2018 7:39 pm
Panerai7 wrote:Thanks for the tip. Amazon I'm assuming?
This is what I got
Canopus Group - 3M Scotch Brite Scuff Pads Very Fine and Ultra Fine (6 Pack) (3+3) https://www.amazon.com/dp/B075VCGBM1?ref=yo_pop_ma_swf
Post by ericf4 » Sun Feb 11, 2018 7:42 pm
It Last Forever as I just cut off a very small 1-inch piece and I use it for a long time before I cut off another piece. This way the smaller the piece the easier it is to control while using it
Post by Panerai7 » Sun Feb 11, 2018 7:49 pm
Brilliant, thanks Eric
Post by dnslater » Mon Feb 12, 2018 4:58 am
I've never owned a Rolex, but typically most nicer watches have much nicer brushing than the green can provide. Green matches a $200 Seiko bracelet or $500 boutique brand bracelet just fine.
I've had good luck using these cheap multi sided nail blocks on better bracelets. You can start with the roughest to get out deep scratches and work towards the finer sides until the brushing matches. Wouldn't touch a case with it though.
Steve O.
Post by Steve O. » Mon Feb 12, 2018 6:19 am
Geez, I can't believe how some of these morons handle an expensive, or any watch for that matter.
Post by Panerai7 » Mon Feb 12, 2018 6:29 am
I know right? He's clearly sliding the face of the watch on something hard like a patio glass table or something. I couldn't watch anymore.
Post by Panerai7 » Mon Feb 12, 2018 6:32 am
Wonder if anyone knows what the final grit number Rolex uses to match it perfectly, sounds like Eric had great success with the Grey one.
Here's something I googled on 3m pads
3M Scotch Brite Nylon Pads:
7445 - White pad, called Light Duty Cleansing - (1000) 1200-1500 grit
7448 - Light Grey, called Ultra Fine Hand - (600-800) 800 grit.
6448 - Green (?), called Light Duty Hand Pad - (600) 600 grit
7447 - Maroon pad, called General Purpose Hand - (320-400) 320 grit
6444 - Brown pad, called Extra Duty Hand - (280-320) 240 grit
7446 - Dark Grey pad, called Blending Pad (180-220) 150 grit
7440 - Tan pad, called Heavy Duty Hand Pad - (120-150) 60(?)
Green Scotch Brite is available EVERYWHERE. It's 600 grit.
Blue Scotch-Brite is considered to be about 1000 grit.
(The value inside the parentheses is directly from 3M.)
3M Chart
Less Aggressive --------> More Aggressive
7445 7448 6448 7447 6444 7446 7440
Post by raf42 » Mon Feb 12, 2018 7:14 am
FWIW,
I've used the light grey (7448) on both Omega and Rolex clasps for very light touch ups. Worked very well on the Omega clasps and seems to match the factory brushing on my SD4K clasp quite nicely.
Post by ericf4 » Mon Feb 12, 2018 7:18 am
light grey is the way to go.
Post by Panerai7 » Mon Feb 12, 2018 7:29 am
Thanks guys, ordered from Amazon.
Post by ericf4 » Mon Feb 12, 2018 7:29 am
Post by Panerai7 » Mon Feb 12, 2018 7:41 am
Yeah, 7448 seems like the way to go.
MDF
Post by MDF » Mon Feb 12, 2018 9:47 am
Holy crap that dudes nuts! I mean that watch is trashed, he's not very careful at all. I need to find out his username so I NEVER buy a watch from him!
Mark
Post by nweash » Mon Feb 12, 2018 10:26 am
First time he looks at that finish in direct sunlight.
Users browsing this forum: DEMO, Google [Bot], mellonb1, rafy11, TLgdeL, tmw and 650 guests
