Spring Bar Pliers
Spring Bar Pliers
Post by fastward » Sat Feb 10, 2018 1:11 pm
Bergeron or Horotec?
Re: Spring a Bar Pliers
Post by nweash » Sat Feb 10, 2018 1:16 pm
I used the horofix for my Pelagos and BLNR. Worked great, and 100 bucks less.
Spring a Bar Pliers
Dumb dupe
2ar2c1
Post by 2ar2c1 » Sat Feb 10, 2018 1:21 pm
the 7825 and the 3200 work the best for me:
Post by JP Chestnut » Sat Feb 10, 2018 1:43 pm
I have the horotech. They're fine. Ill be getting a 3200 for exclusive use on my Rolex.
Post by Panerai7 » Sat Feb 10, 2018 1:50 pm
I have the Bergeron tool that looks just like Horotec in Nick's pic. Works great on Rolex and Tudor.
Post by deepcdvr » Sat Feb 10, 2018 1:50 pm
I typically use a sharp knife.
That has caused me to use a drill as well
NEVER SETTLE!
Post by fastward » Sat Feb 10, 2018 5:03 pm
My skill set is slightly different. :salute:
I’ve used two screwdrivers in the past, but feel like it’s finally time to buck up and go for the pliers.
Post by Chocodove » Sat Feb 10, 2018 5:08 pm
I have the Horofix ones. They work fine. Much better than the standard spring bar tool. Still a pain in the ass IMO, but that says more about my technique than the tool.
Post by toxicavenger » Sat Feb 10, 2018 5:26 pm
How are these better than a regular spring bar tool? Because all I do is apply pressure to back of the lug while I release each spring bar. Just wondering.
Post by fastward » Sat Feb 10, 2018 5:28 pm
I like the concept of locking pliers as opposed to my overly caffeinated hands after a few drinks.
Post by Chocodove » Sat Feb 10, 2018 5:32 pm
toxicavenger wrote:How are these better than a regular spring bar tool? Because all I do is apply pressure to back of the lug while I release each spring bar. Just wondering.
In my experience I am much less likely to scratch the back of the lugs using this than a regular spring bar tool. The ends are tiny enough to fit into the ridiculously tight tolerances of a Rolex bracelet and grab the spring bar perfectly, which my regular Bergeon tool does not.
Post by ericf4 » Sat Feb 10, 2018 5:34 pm
I bought them thinking I'd use them all the time. I never do. Easier with single tool while applying pressure to the lug. Pops right out.
Post by toxicavenger » Sat Feb 10, 2018 5:53 pm
I have one of the Everest spring bar tools with the 1.4mm tip. It works perfectly for the Monta. Is your Bergeon the one with the smaller tip?
Post by Chocodove » Sat Feb 10, 2018 6:03 pm
It’s more getting the bracelet back on. Both ends have to be squeezed, which I find to be easier with a plier type device than a regular tool.
Post by toxicavenger » Sat Feb 10, 2018 6:09 pm
Oh okay. I can see that.
Post by JP Chestnut » Sat Feb 10, 2018 6:09 pm
Taking it off isn't much easier, but getting it back on is MUCH easier... for me.
Post by Chocodove » Sat Feb 10, 2018 6:13 pm
Exactly.
manitoujoe
Post by manitoujoe » Sat Feb 10, 2018 9:42 pm
Wait. So how is this different than a spring bar tool? Does it do both ends at the same time?
Steve Martin
Selym
Post by Selym » Sat Feb 10, 2018 10:14 pm
Yes.
manitoujoe
Post by manitoujoe » Sat Feb 10, 2018 10:41 pm
Sweet. I think I should look into getting one. The single tool is too fiddly sometimes. Thanks
Steve Martin
Post by dukerules » Sun Feb 11, 2018 4:32 am
Horofix for me. Mainly because they're much cheaper than the Bergeron.
Post by fastward » Sun Feb 11, 2018 8:23 am
I was leaning towards the Horofix for the same reason.
Post by Chocodove » Sun Feb 11, 2018 8:30 am
I am not sure what watch you plan on using these for, but if ever a Rolex, from what I understand the Bergeon pliers need to have the tips filed down slightly to get to the correct size. The Horofix are already good to go. If you do a search at TRF you'll see what I mean.
Post by JP Chestnut » Sun Feb 11, 2018 8:34 am
That why I bought the horofix. However, it's definitely not as nice, and one of my thin tips showed up defective.
Users browsing this forum: AzRincon, Chocodove, ericf4, Google [Bot], gwells, Joeprez, JP Chestnut, logan2z, raf42, TLgdeL, tyd450 and 29 guests
