Shock damage
- james80
- Name: James
Shock damage
Let me start by stating the following:
Yes I searched online (some of the threads on WUS are fascinating).
No I don't think this is WUS.
Yes I'm fully prepared for the consequences of my post.
That said, I was playing pool last week wearing my Carrera Chrono (7750) and during each break I felt the rotor spinning and wobbling like mad (I break with explosive force!! Ok no I don't) and I got to wondering if it's possible to create enough shock to do damage.
Re: Shock damage
I wouldn’t think so, but I guess anything is possible.
- 59yukon01
- 1.21 gigawatts?!
Re: Shock damage
Probably no more so than masturbating with your watch on.
Shock damage
- Louis CKLouisCK wrote:Probably no more so than masturbating with your watch on.
Too soon?
Re: Shock damage
OK....WUS answer....you do know the 7750 wobbles and its normal?
instagram @watchidiotsavants
Re: Shock damage
No worries. I’m no chrono expert, but I know the 7750 has a noisy rotor.
- Morethan1
- Frequent bumper of posts
- Name: Alex
Re: Shock damage
Maybe the rotor screw has come loose?
- james80
- Name: James
Re: Shock damage
hobbit712 wrote:OK....WUS answer....you do know the 7750 wobbles and its normal?
Very familiar with the wobble. I guess the action just exaggerated it.hoppyjr wrote:No worries. I’m no chrono expert, but I know the 7750 has a noisy rotor.
Nothing happened to it I was just wondering if it could.Morethan1 wrote:Maybe the rotor screw has come loose?
- TimelessLuxWatches
- Name: Brett
Re: Shock damage
Yes, a sufficiently large shock is capable of damage.
However, it's unlikely that it suffered this. The 7750, like many unidirectional winders, uses a heavy rotor. Combined with its unidirectional nature, and therefore the lack of resistance in the non-winding direction, this can create somewhat unnervingly high-RPMs and "rotor whir" or noise. But, short of something truly interesting, this will cause no damage and insignificant wear.
Re: Shock damage
Check the battery hatch. Sometimes it gets kicked out of place when the rotor bumps into it
- Heuerville
- Name: Stewart
Re: Shock damage
James, you need to take a long hard look at yourself man.
Pull your shit together, and when you're ready, come back with a heartfelt apology.
"SOB get me a drink"
Re: Shock damage
you're lucky the watch didn't fly off your wrist with that rotor whirlybirding
- james80
- Name: James
Re: Shock damage
You guys need context. You'd have to have been there to see just how powerful my break shot was!
- james80
- Name: James
Re: Shock damage
- Heuerville
- Name: Stewart
Re: Shock damage
- mikeylacroix
Re: Shock damage
I wore my xp2 to ride...it over torqued the spring(high amplitude)
the 'bounce' caused a jewel to get loose and subsequently the spring was done for.
On regular use it kept good time, otherwise it was all over the place
2cents
2cents
- james80
- Name: James
Re: Shock damage
Just to be clear I didn't think anything happened to my watch but got to thinking if it was possible. That said I have no defense, guilty as charged, I'll get my coat.
Sorry Stu.
Sorry Stu.
Re: Shock damage
you'll be fine as long as it wasn't raining when you were playing pool. all that force with some moisture will surely ruin it.
- james80
- Name: James
Re: Shock damage
It was! And I'll tell you my arm action is explosive. Water would've been forced in for sure.gwells wrote:you'll be fine as long as it wasn't raining when you were playing pool. all that force with some moisture will surely ruin it.
- james80
- Name: James
Re: Shock damage
Re: Shock damage
ah, so you used your masturbation arm to break, then.
- james80
- Name: James
Re: Shock damage
Nope. Didn't want to break the balls!
Re: Shock damage
Why? They weren’t yoursjames80 wrote:Nope. Didn't want to break the balls!
- JDC222
- Demander of Intro Threads
Re: Shock damage
You’re lucky that you weren’t electrocuted buddy!!james80 wrote:It was! And I'll tell you my arm action is explosive. Water would've been forced in for sure.gwells wrote:you'll be fine as long as it wasn't raining when you were playing pool. all that force with some moisture will surely ruin it.
Users browsing this forum: DaveT, DocHollidayDDS, Google [Bot] and 716 guests
