Morning all,
Not sure if this has been posted. Looks pretty good, specs are really good at this price point. I really like case shape and especially the narrow lug ends. Drilled lugs also a bonus.
Some specs.
SIZE: 43 x 48 MM – LUGWIDTH 22 MMAUTOMATIC SEIKO NH35 MOVEMENT - 24 JEWELS – 21600 BPH SUNRAY SANDWICH DIALC3 SUPERLUMINOVA ON DIAL, HANDS AND BEZELBRUSHED STAINLESS STEEL CASE (316L STAINLESS STEEL)AR-COATED DOUBLE DOMED SAPPHIRE CRYSTAL120 CLICKS UNIDIRECTIONAL BEZEL WITH CERAMIC INSERT200M WATER RESISTANTSCREW-DOWN CROWN WITH LOGODRILLED THROUGH LUGSSUNRAY BRUSHED SCREW-DOWN CASEBACK WITH ENGRAVING OF THE SEAHORSEHIGH QUALITY RUBBER STRAPLIMITED EDITION - SERIAL NUMBERS ON THE BACK
https://www.kickstarter.com/projects/12 ... c1dfba.jpg[/IMG]
Sent from my SM-T580 using Tapatalk
Another KS dive watch. Diewald
- stonehead887
- Name: Jeremy
Re: Another KS dive watch. Diewald
Thank you. I like the case but would have preferred the markers reversed, meaning the point of the triangle on the inside...
- bedlam
- Name: Carl
Bit of a mash up; Zodiac-ish case, (awkwardly) reversed Eterna markers, and a Breitling bezel. Not sure it really works for me.
Users browsing this forum: DocHollidayDDS, mattcantwin and 607 guests
