HELP!! How do I get Stowa Bezel On!
- 1watchaholic
- Name: Gary
HELP!! Emergency!! I just picked up a Stowa Prodiver and I wanted to change the bezel. I read how to get it off and boom...no problem. But now that I'm trying to put the new bezel on it won't stay on and I don't want to screw it up! Stowa experts PLEASE provide me some tips!
Re: HELP!! How do I get Stowa Bezel On!
Don't know about Stowa, but with Seiko bezels you pressure fit and then turn it over on a hard flat surface (preferably over a towel to avoid scratches) and push hard. It should snap in place.
- 1watchaholic
- Name: Gary
Thanks Nick! I just found that too. The key is lining up the bezel notches to the marks on the case. 15 minutes and counting...dnslater wrote: ↑Wed Feb 08, 2017 1:06 pmAlso from WUS:
http://forums.watchuseek.com/f36/how-ch ... 17533.html
You're going to want to put it on when flaccid. Also use a little lube.
Get a small hammer and a flat head drew driver
- 1watchaholic
- Name: Gary
No help at all from the State of Washington! 30 min and counting!
I believe the bezel on the Stowa sits slightly higher than the crystal, so...
Have you tried lining up the bezel, then carefully placing it face down on a hard surface and applying even pressure?
Be sure to place a soft cloth between the watch face and hard surface.
Not guarantees, but I've used that technique before.
FWIW, this technique works for other stuff too.
- 1watchaholic
- Name: Gary
Thanks Bro! Well after a freaking hour the bezel is on. The whole secret to the job was lining up the markers. If they are a hair off when you exert pressure nothing. Well I'm going to wear this puppy the rest of the evening in celebration of my first bezel replacement. I guess everyone's first time is a little clumsy!!
Users browsing this forum: demer03, jswing, mattcantwin, pbj204 and 331 guests
