Advice? Should the watch go back?
Gents- you know how you can look at a watch too much and pick out the nit-pickiest of flaws? I don't think this is one of these. Was looking at my new Orient Mako USA and noticed that the bezel insert doesn’t seem to be sitting flush like it does on my Pepsi Mako. Not sure if the new sapphire crystal sits lower than the old mineral crystal, but I have never had this much space on a watch. Am I off-base, or should I have Orient take a look?
Here is what it looks like:
Here it is with a scrap of paper inserted.
I drew a line where the paper stopped.
- jswing
- Name: Jeff
Re: Advice? Should the watch go back?
I think I'd send Mako (or the seller) an email and ask if it's normal. Maybe it is, and then you don't have to worry about it, and if it's not get it replaced. Seems like it could possibly effect WR if it's not right.
Is the bezel fully seated and does it turn ok?
no bueno - I've never handled one but I can't imagine that is safe around water with that gap like that.
Someone who has owned one will stop by and clarify
Yep, bezel turns just fine. The part that is sticking up is the thin metal insert into the bezel. If memory serves, Jay at MCWW popped the metal part out of my Pepsi Mako, cerakoted the bezel, then reinstalled it into the bezel. I don't think it would have any effect on WR, but is a good place to collect ick, and catch on stuff. Given how thin it is, looks like it would bend easily if struck since there is no support beneath.dnslater wrote:Is the bezel fully seated and does it turn ok?
No idea if this is normal. As advised, ask Orient if it's bothering you. However, if the bezel turns fine and doesn't wobble or otherwise seem loose or misaligned, I imagine it's fine. Regardless, I don't believe this would have any affect on water resistance.
- t20569cald
never handled this watch, but also never handled a watch that had the bezel seated like that.
I would certainly send those pics to Orient
The gap is between the bezel insert and crystal, so no impact on WR. Just bad tolerances by Orient. Probably not a good beach watch for this reason.rockmastermike wrote:no bueno - I've never handled one but I can't imagine that is safe around water with that gap like that.
Awesome, thanks - learned something new toadydnslater wrote:The gap is between the bezel insert and crystal, so no impact on WR. Just bad tolerances by Orient. Probably not a good beach watch for this reason.rockmastermike wrote:no bueno - I've never handled one but I can't imagine that is safe around water with that gap like that.
Hard to say Karl. Looks like a semi-big gap, but have never seen this watch
in person, or up close. Only have a regular Mako, but it doesn't seem to have
a gap like this. ..Would maybe have Orient check it out if it's bothering you.
Theory (via PM discussions) is that Orient went thinner when they switched to sapphire. With the standard crystal, the top of the bezel insert would touch the crystal. I think this was a bad (possibly money-saving) move.
I don't like that at all. That's going to be filled with sand, sand, more sand, and some other non describable stuff in a while.
If this is money saving by Orient then the brand is going even more downmarket to meet a price point that is not sustainable. It does not move your customers into the next product level but away from your brand almost completely.
What is really disappointing is that if this is the "new" Mako with upgraded sapphire and bracelet then they've really screwed the parts list and the fabrication process end to end. Either you are good or great and low cost, or just low cost and s**t.
Beaver? It's a damn badger - it even says so on the poster....
Gordo.
Gordo.
Especially since the bezel insert is a very thin sheet of easily bent metal. With no support, it will resemble a waveform in no time from relatively benign bumps against stuff.braeburn wrote:I don't like that at all. That's going to be filled with sand, sand, more sand, and some other non describable stuff in a while.
That's an excellent follow-up. The edges are unsupported if this is indicative of the production run. Crinkled edges may be the rule and then the bezel might not turn.KLR_Redux wrote:Especially since the bezel insert is a very thin sheet of easily bent metal. With no support, it will resemble a waveform in no time from relatively benign bumps against stuff.braeburn wrote:I don't like that at all. That's going to be filled with sand, sand, more sand, and some other non describable stuff in a while.
Lot going on here.
Gordo.
Gordo.
I've just checked my Mako and its flush. That gap would definitely bug me. I've stopped wearing watches for less. Good luck with it.
Vanitas Vanitatum, Omnia Vanitas
